Question about GE WWSE5200B Top Load Washer
WWSE3160AOWW A loose nut or something rattling around and can't get agitator off to look.
  • 20 Answers
Use a belt to put under the agitator to decompress the clips on the bottom of the agitator. Pull up at the same time you decompress the clips.....carful not to knock yourself in the chin
Posted on May 07, 2010
Testimonial: "I like the solution, very much. It's simple, effective and I appreciate the cautioin about my chin. Only those well versed in a subject can make a solution so approachable, not intimidating. Thank You."
WHEN STARTING KIA 2008 SPORTAGE A NOISE SOUNDING LIKE LOOSE BOLTS OR NUTS FALLING AROUND.LIKE SOMETHING KNOCKING AGAINST A COVER OR SO.GOES AWAY AFTERWARDS THEN COMES BACK WHEN IDLING ..
hydraulic lifters fitted to that engine
shimmed adjustments
that rattle on start up will happen
takes a few seconds to fill with oil
if lifters are worn
motor run low on oil or not serviced regularly
faulty ones can be replaced
other rattles can be idler pulleys
Oct 28, 2016 | Kia Cars & Trucks
Agitator Rattling
There are no washers of any sort on the Dyson's agitators. There are molded caps on each end, made to fit into the bracketry on the sides of the nozzle portion. If there's it seems as though there's something missing then you'll need to purchase a complete agitator, there are no replacement parts for agitators.
Nov 08, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Agitator keeps rising up and washing getting stuck/twisted underneath
The nut that holds the agatator on has come loose and is properly floating around in the agitator.Or it just needs to be pushed down to lock it in place. At worst the bolt and nut has rusted away. (repair man)
Dec 21, 2010 | GE Washing Machines
Agitator loose
lift out the softener cup located on top of the agitator,there is a 7/16" nut bolted down into the agitator spline that may have come loose
Jan 16, 2010 | Washing Machines
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Jul 30, 2009 | GE WSXH208A Front Load Washer
Noisy/loose agitator
remove the top piece of the agitator. this is a dispenser. then remove a cap that is at the center of the agitator. there is a bolt there that is holding the whole agitator. remove the bolt and you can pull out the whole agitator. be careful in removing, the thing could just separate to pieces and you may have a problem assembling it again.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Washing Machines
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
GE WWSE5200B Top Load Washer Logo
184 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
