Question about Denon AVR-1707 Receiver
Wii to a AVR 1610 via DVR input
I connected my Wii to a AVR 1610 via DVR input using a component cable. The connection worked. My only problem is picture is not fulls screen n i.e black bands at edge of screen. Its neither a 4:3 nor 16:9...i have checked my samsung 50" plasma tv and aspect ratio is 16:9. Cld anyone help?
    Brigadier General:
  • 8,546 Answers
"A" (single) component cable? Really? Not composite?
The source determines the aspect ratio of the video. If you decide to change it, that's your choice but it isn't accurate. 4x3 is intended to be shown 4x3. A circle will be elongated if you stretch the image to fit the screen.
Disregarding the black bars, is the geometry of the image correct? If so, why can't you just go with it?
If you want to change how the TV treats it, you'll have to refer to the TV's manual and controls.
Posted on May 06, 2010
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Connect wii to Avr 1312 Denon
What you would have to do is connect the video output of the wii directly to the video input of the bug projector. Also connect the audio cables to it as well. Then connect an audio cable to the projector's audio out or otherwise labeled as "variable out" then connect the other end of that to the matching input terminal, found often labeled as "audio in" on the receiver's grouping of input selections for TV.
Then, on the projector, select the video mode you connected the wii cables to.
Jun 18, 2012 | Denon AVR 1312
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
I am trying to connect my wii to my denon avr-2802 using the wii's composite cables. i get sound but no picture. help.
After connecting the Wii cables, connect a video cable to the "monitor out" connection to a compatible input on the TV.
Feb 15, 2010 | Denon AVR-2802
I just purchased a denon avr-1610 receiver and I cannot get picture back to my tv through the hdmi. I have a starchoice dvr which is dvi to hdmi, I come out of my satelite into sat/cab then out of my denon...
One possible reason is the HDCP (copy-prevention)-encoded signal from the DVR, which will transmits through to one device (the receiver) but not to a second (the TV). As an experiment and a possible solution, try reconnecting the HDMI cable from the DVR directly to the TV (provided you have an extra HDMI input on it), and using the component-video or S-video plus either digital or analog audio outputs to connect your DVR to the receiver. If this works, I think that the HDCP is the problem and this is the only solution.
It may be a little inconvenient to remember to switch inputs on the TV as well as the receiver, but you could probably program your remote with a macro to do both. The component video (or, more likely, the S-video) is also the best possible video signal you can use for dubbing to any DVD recorders, if you have one connected to the same receiver. You can still keep the HDMI connected from your PS3 (or other BD/DVD) player to the receiver, and from there to the TV, since that does seem to work -- if you don't mind turning on the receiver every time you want to watch a BD or DVD. My recommendation, however, is to connect all your video signals directly to the TV via HDMI or component, and use the receiver only for audio, or for switching of lower-level video signals like S-video that you can use for dubbing. That way you can always check the DVR or BD or DVD quickly without powering up your receiver, which takes a few seconds and much more power.
Feb 13, 2010 | Audio Players & Recorders
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Dec 28, 2009 | Electronics - Others
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Denon AVR-1707 Receiver Logo
199 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
