Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
HOW TO SET TV TO RECEIVE ALL CHANNELS AVAILABLE USING THE REMOTE SETTING
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
You need to go to the menue and then to auto prgram mode that will auto lock all chanels you can get
Posted on May 06, 2010
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Technika tv
You might need to set up the channels in the menus. Try auto scanning the channels. Read you operating manual on setting up the TV.
Oct 23, 2013 | Televison & Video
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We are getting a weak signal, no picture.
Make sure that at the box you are connecting the antenna in the right "Ant" connector at the converter and using the other connector to jump to your TV set "antenna in" connector, and have your set tuned in channel 3 or channel 4 (try both, just in case).
Another thing you may want to check is that your TV is set to receive channels "From the Air" not "cable". use you TV menu selections to find this setting.
You may also choose to connect the signal transfer from the converter to the TV using a 3 cable set of Audio (red and white RCA connectors) and a video cable (yellow connector) and setting your TV to get the "signal input" from the right input selection, (it could be labeled as Front, or Video or Aux) in this way you will get a even better image quality.
Then press "menu" on your Digital TV converter remote, then if and when you can see the menu in your TV, look and go for auto setup so the converter can look and find all the available channels in your area.
If there is nothing broken you should be able to get you Digital programming right there.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Sep 11, 2006 | Panasonic PV-M1349 Combo
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
