Question about Xerox WorkCentre XD125F All-In-One Laser Printer
How do I reset the drum counter?
I need to reset the drum counter but don't know how.
  • M Y Mar 27, 2008
    No problem, thanks for catching it! I'll give this a try and let you know how it goes. Thanks again!
    President:
  • 2,072 Answers
You have to replace the chip on the drum cartridge. You can order one at this location.
https://www.partsdrop.com/store/
Posted on Mar 27, 2008
  • Rick Kasper Mar 27, 2008
    Disregard, I gave you the info on the wrong machine,
    I misread.
    What you do is pop the front of the drum off. There is a set of gears in the front. What you want to do is move the flag like part of the one gear up and to the left. It will run and slip past the reset switch and reset the count. You may have to try it 3 or 4o times but it drops to the bottom. You have to reset it to the top and allow it to drop down past the reset.
    I am so sorry. An older machine clicked into my mind when I first read this.
    There is no chip on the XD drum just that set of gears on front.
    Once again my apology.
3 Suggested Answers
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
Jimsta01
  • 405 Answers
SOURCE: how do I reset the drum counter on the a Brother
open the front cover of machine ( where the cartridge is installed), then press the clear button, and then press 1 for yes for change drum question.
Posted on May 16, 2010
Minolta Dialta Copier Di152, code reads 32-COF
Replace the developer and developer unit. And Replace the drum normally done together make sure to reset the drum developer counters because the machine use the counters to set voltages to the drum and developer and it is the only way the copier knows it has a new drum and developer reset the counters without replacing the drum and developer causes code sand image problems
Sep 16, 2012 | Minolta Office Equipment & Supplies
In Konica Minolta bizhub 362 it says ready to copy but I noticed it says "please change PC drum"
Thecopier has a counter the drum unit. "PC" means photo conductor, I don't remember if the copier will lock up if the drum unit is not replaced? There is a counter that needs to be reset once the drum & new developer is installed.
Jul 19, 2011 | Office Equipment & Supplies
We just replaced the drum and now are getting 'shadow' images of our documents on every copy. The image starts about half way down the page.
After replacing the drum, did you reset the drum counter? Also, it is best to change out the developer at the same time you replace the drum, this is because both the drum and developer need to be calibrated with each other.
It sounds like you didn't manually reset the counter and now the charge on the drum is to high, I would suggest not using the machine until to reset the counter.
Let me know.
-David.
Nov 05, 2010 | Sharp AL 1631 Copier
The toner light is on and my printer wont print
If the toner LED still lit even after replacing the drum unit then you know that the Drum counter may not be reset. you need to reset the drum
you can rReset the Drum counter as follows:
The Drum counter is now reset.hope this helps
Jul 08, 2010 | Brother HL 2140 Laser Printer
I changed the drum but it still reads drum error and i am not receiving faxes. There is a ring so the connections are working. I cant get in to the area where it reads drum set.
Need to know Make and model to be sure.
However, many new machines reset the drum counter by blowing a fuse in the drum cartridge or by recoginition of a new chip in the cartridge. Some require a "Service code" access to reset counter after the drum has been replaced. Need specifics to be more help.
May 11, 2010 | Office Equipment & Supplies
I need to know how to reset the drum counter on a brother HL6050D
Turn off printer. Open top cover, where you inserted the new drum. Switch printer on, count to ten...close cover. Drum counter is reset. Simple.
Nov 16, 2009 | Brother HL 6050D Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Copier drum reset code
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Jan 03, 2009 | Office Equipment & Supplies
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Aug 28, 2008 | Office Equipment & Supplies
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
186 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
