Question about Sony Cameras
Super Steady shot 5.1 mega pixels. Camera auotmatic shoots off, when you turn it on.
  • 11967 Answers
SOURCE: Sony cybershot digital camera with a stuck lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 03, 2010
SOURCE: I have a sony cyber-shot 1.3 mega pixels camera
Did you find the manual and disc you were looking for? I have them and might be able to help you buy making copies for you if you are interested. write me at barneysworld@zoominternet.net my name is barney I love that camera and use it everyday. I am finally looking to upgrade from 1.3 mp.... I paid $350.00 for that camera in 2001... can you believe what you can buy for $350.00 in cameras now??? I have had to buy 3 teenage daughters and their mom cameras in the mean time, I just got my 16 yr. old a Nikon 3000.... that stuff was expensive. Let me know about the manual, sincerely, ( I have kept it all these years for something , it must be for you.) I will help you if I can.
Posted on Jun 29, 2010
  • 102366 Answers
SOURCE: I have a sony super steady shot 5.1 mega pixels
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 15, 2011
tntcy
  • 21 Answers
SOURCE: i have a sony
It means that a camera malfunction that you cannot reverse has occured.
You can try to press the reset button located inside the jack cover and then turn on the camera again.
Posted on May 22, 2011
  • 84 Answers
you can buy here:
http://cgi.ebay.com/SLAVE-FLASH-SONY-CYBERSHOT-DSC-H1-DIGITAL-CAMERA-/120604081156?pt=Digital_Camera_Flashes&hash=item1c14903c04
Thanks for using fixya.
Posted on May 24, 2011
I have a polaroid 16 mega pixels digital camera. most of my photos blurr. what can I do to improve quality of the photos. it is indoors so the flash is on auto.
Blurring is due to motion of the camera when the shot is being taken. The higher the resolution, the more steady the camera has to be to take good shots. Try using a solid surface to rest the camera when taking shots, and also practice "shooters breathing" when taking those "once-in-a-lifetime" shots. Practice makes perfect.
Aug 19, 2016 | Polaroid Cameras
Setting my Samsung ST76 to 1MB photos
I do not complete understand what you want. My fuss is, you want every picture to be about 1 MB on your memory card. I do strongly advice against this, but you own the camera and so it be. You always can make pictures with a smaller resolution from high quality pictures, but never the other way around. You better shoot highest quality on your camera and later wham the pictures are on your computer down size the ones that are less important to 1 MB.
But you can choose 5 mega pixels with normal compression or 3 mega pixels with fine compression or 2 mega pixels with super fine compression. All these pictures will look fine in an e-mail, or on the net. Even a 6 by 4 inch picture will look fine. Memory cards will cost like 1 dollar pro Gbyte, so my advice is buy a few 8 or 16 Gb cards and shoot in high def.
Nov 25, 2013 | Samsung Cameras
I'm looking for a manual for a Sony Super Steady Shot DSC-T10 7.2 MEGA PIXELS CAMERA
You can download the manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT10
Jul 10, 2011 | Sony Cyber-shot DSC-T10 Digital Camera
Hello, I have a sony cyber -shot 7.2 mega pixel.....I would like to transfer my pics from memory card to a cd. can this be done at a store?
Hi
Well you can copy all to your PC and later burn to a DVD with the settings choosen in the writting software as PHOTO DVD and you are done.
RATE MY SOLUTION
Jul 07, 2011 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I have a sony 8.1 mega pixels super steady shot dsc-t100 .cyber-shot it got a e61 10 fault can u help
May 22, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
I need a copy of the owners manual for my camera, it's a Sony Super Steady Shot DSC H2 with 6.0 Mega Pixels.
Hello
OK, you will be able to download a copy of the manual requested HERE.
Kind regards
Andrea
Sep 13, 2010 | Sony Cameras
I WANT TO SEND 11 PAGES OF A DOCUMENT BY EMAIL HOW CAN I MAKE IT SMALLER
Turn down the picture quality and it will require less memory
Example 10 mega pixel camera
change it from 10 Mega pixel to 5 mega pixel
Mar 07, 2010 | Fuji FinePix 2600 Zoom Digital Camera
Flash shows a triangle with an exclamation pnt "can not be chngd
the flash can not be forced on on some shooting modes, just try other modes(auto.etc)
Apr 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Cameras Logo
303 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
