Question about General Electric WHDSR316G Top Load Washer
Ge washing machine #whdsr316g1ww bucket is banging against front and sides of machine.
catriver
  • 878 Answers
SOURCE: Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the attachments...Catriver..post back
Posted on Sep 07, 2006
  • 46 Answers
SOURCE: Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Posted on Feb 08, 2008
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
SOURCE: no spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Posted on Nov 03, 2009
SOURCE: I own a GE WBSR3140 Washer and I'm getting a
First of all, you do remove the a panel from the front.
On the inside floor of the machine, there were two "L" brackets with a hole for bolts, There were also two brackets on the bottom of the tub with similar holes. One pair was on the left bottom side and the other was on the bottom right.
It appeared that a bolt or some type of "dampening" connector was meant to go through to these holes. But there were no broken parts lying inside.That was my first "guess" for their purpose.
The left side (as facing the machine) "L" floor brackets and a tub bracket had been " bent" in such a way that that when the tub shook enough, the two brackets prevented the tub from moving too far. But not the pair on the right hand side. Go figure.
How it ever got this way or whether this was a "jury-rigged" solution at the factory (because they ran out of parts) is beyond me. Maybe the two brackets were meant to act as some form of "stop". But why were bent in such a fashion? And why only the ones on the left bottom side of the machine? I swear somebody bent them on purpose but that's me.
In any case, the tub had moved far enough that the bent tub bracket had slipped around the bent floor bracket. When ever the machine was on "wash" or "rinse" this "configuration" would bang against each other loudly. But it would not happen during the "spin" cycle.
I simply bent the two left hand side brackets back into a someone normal configuration (as with the bottom right floor and tub brackets) and put every thing back together. The banging sound was gone. However, you could still hear the brackets hitting each other on heavy loads. But it was not the "BOOM" I was getting before.
Eventually, the four rubber top corner "shock" springs will need replacing but at least things are quiet for the moment. But why or how the left bottom tob and floor brackets got so bent out of shape is beyond me. "Human intervention" or normal "wear and tear"?
Mark
Posted on Dec 22, 2009
Banging noise comming from back of washer near the belt
I have a GE WHDSR316G1WW top loading washer and the drain hose located on the upper left rear of the plastic outer tub came loose. It sounded like a worn seal or bearing because it was banging so loud. I removed the control panel, top panel and front panel, reattached the drain hose into the housing hole and the problem was solved. Saved $80 service call.
Aug 15, 2013 | Kenmore 24032\24036 Top Load Washer
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
Feb 24, 2013 | GE Washing Machines
Inner drum of GE front load washer is very loose and is banging against the sides of the outer drum.
The rear spider shaft has broken it can be repaired. but I'm not 100% on lg units a lot of newer washers have a complete tub unit now it's all sealed in would need to see the machine with the lid off.
Dec 10, 2012 | Washing Machines
The bucket is banging back and forth violently causing the machine to move around. We made sure the load was evenly distributed but it continues to bounce around at the 15 minute left mark on the cycle...
Check the suspension rods inside the machine. Sound like one has come off or has broke. Here is a link to the part if you need it. The white ones are for the rear of the tub, and the green ones are for the front.
Jan 04, 2011 | GE Profile WPRE8100G
Cannot get drive belt on ge washer model #whdsr316g1ww
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
Feb 25, 2010 | Washing Machines
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
General Electric WHDSR316G Top Load Washer Logo
128 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
