Question about EliteGroup L4S5MG/651+ Motherboard
I have an Elitegroup L4S5MG/651+ motherboard that won't keep time. I've changed the CMOS battery, changed date and time in the BIOS setup and the Internet Time in the Time & Date properties.
    Genius:
  • 1,027 Answers
Is the automatic clock setup enabled in Windows - that will reset the clock, most likely to the wrong time zone.
Posted on May 06, 2010
Cmos checksum error-defaults loaded
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program.
This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty.
It could also be another component on the motherboard.
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
Aug 03, 2012 | Dell Computers & Internet
Problem with BIOS. Cannot change system date.
Put all default setting on CMOS setup and then set the date by checking that the replaced one battery is energetic enough to meet the system requirement. I mean to say having 3V as it should have.
best of luck!
Mar 11, 2012 | ASUS Motherboard P8P67 PRO REV 31 Core...
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation.
Good luck.
Dec 27, 2011 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
Soundcard driverL4S5MG/651 Motherboard
This is the Driver that your motherboard sound card use: C-Media CMI9738 and you can download it HERE just write alphanumeric code that request the website and click where it says "Descargar" then the download starts automatically.
Aug 27, 2010 | EliteGroup L4S5MG/651+ Motherboard
Having trouble having to reset the date each time I start the puter. I've replaced the battery twice in the last 3 weeks so that's not the problem. I keep getting CMOS error. Help?
pop out your battery and replace it with a new one and reset your bios by changing the jumper to the next position that is covering pin 2 and 3.... and set the time in cmos...... you are there.... pls vote if you like this solution.....
Jun 16, 2010 | EliteGroup K7S5A Pro Motherboard
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup L4S5MG/651+ Motherboard Logo
173 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
