Question about Garden
Need to get Rusted NUT off Armature of Electric Mower from Hell.
I am trying to get the rusted on nut off of the blade on a Craftsman Electric lawnmower, 900370510. It turns with the armature. So, the square plastic washer spins under the square metal washer with the nut that is rusted on the motor.
I've used CRC, wrenches, 2x4's to brace it, propane & a little mapp gas. Problem is, the whole thing has plastic parts which will break if you chock it. It looks like the mower has quite a few years on it.
PS, it is a LH thread, @#$%!
Would someone tell me the golden answer? I don't want to buy the lady a new motor.
Thank you
  • 468 Answers
I find that nut splitter work ok on occasion if you can get one in there, and just replace the nut(sounds like that's going to happen anyways regardless) , or pick it up, set the nut on a solid piece of steel, so that it's supporting the weight of everything, and hit the other side of the nut with a hammer, or a hammer and chisel, with the chisel perpendicular to the shaft and the blade splitting it the long way. Other tricks, are to heat it up red-hot, and hit it with water immediately, or even canned air inverted(will freeze it instantly) in order to get the surfaces to change enough to break loose. Hope these helped; they've been standbys for me for years.
Posted on May 06, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cannot get the blade off of this lawn mower
The blade retaining nut or bolt is usually reverse threaded. If it's rusted on there pretty good you might try soaking the fastener with PB Blaster for a few hours. Wedge a block of wood between the blade and the mower deck, then while grasping the blade with a gloved hand push the blade and the socket wrench towards each other so you aren't fighting the blade spinning around.
Nov 24, 2012 | Garden
I have a B&D electric mower M300. I need to take
you need to use some plyers and hold the shaft with them
May 31, 2011 | Craftsman Garden
Exhaust front pipe nuts rusted on
Try using a size 10 metric thin walled socket drive to fit nut with a little force. Use plenty of WD-40, soak the nut and stud. Try to turn nut for 1/8 turn forward, spray WD-40 then turn bolt back until it feels that it is stuck, turn nut 1/2 turn forward, spray WD-40 and try again to unbolt, everytime it feels it is stuck move nut forward, spray WD-40 then try again to unbolt. It is a slow process as it to prevent stripping the rusted nut and stud. Have fun.
Apr 15, 2010 | 2005 Gilera Runner VX 125
How do I remove the old broken lawn mower blade. I can't seem to keep the bolt and nut from moving together when I try to loosen the bold. thanks in advance
i uses impact gun with 3/4 " socket.run it in reverse or you have to remove the stationary parts of the motor.mark them so u will know how to put them back together & somebody has to hold the armature will u r turning the nut on the blade.
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
HOW TO TIGHTEN MOWER BLADE NUT
check out www.toolpartsdirect.com for parts diagram for proper installation. the 2 last step is the square metal washer then the nut. to install the metal washer the match the shaft guide. if still can't tighten the nut then the problem is the armature ring may drop down.
Jul 04, 2008 | Black & Decker 19" Electric Lawnhog...
I need to change the blade, but am unable to loosen the nut holding the blade in place. the nut and square spacer underneath move together.
you need impact gun.air or electric operated impact,run it reverse. it shouldn't be loose like that. i am guessing the armature drop could be the ring is out of the armature groove. ring are located inside the motor assy.
Jul 01, 2008 | Black & Decker 19" Electric Lawnhog...
Blade assembly does not tighten
problem could be the armature ring/ drop. it's for the bearing stopper. if the ring slip off from the grove, all you to do is to put it back to the grove & make sure that the grove are in good shape..its common problem for older armature type.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
