Question about Garden
Cub Cadet LT1050 lawn tractor won't turn over and start. Starter motor does turn, but flywheel doesn't turn very fast, and stalls each revolution at the top of the compression stroke. I can turn the flywheel past this point with my hand on the flywheel screen, although it is difficult. I first thought "low battery" but I jumped the tractor with a deep cycle marine battery and although i get very bright lights and good spark on the engine ground, the starter motor still won't turn the flywheel past the high compression spot of the rotation. I'm guessing the starter motor isn't generating enough torque, but I don't know how to test for that. It does turn when hooked directly to the jumper battery. I'm not brave enough to try to stall it with my hand. Any ideas on how to diagnose this?
Three people i know plus myself have this same problem with this same model tractor. new starters and new batteries did not help any of us
Posted on Aug 15, 2010
    Problem Solver:
  • 13 Answers
I would take the starter off and go to Autozone, or a small motor shop and have them test it.
Posted on Jun 10, 2010
Engine starter spins and will not start motor somethines.
Remove the engine cover to expose the starter motor (or take the starter off). Lubricate the starter bendix, its the gear atop the starter motor shaft, use Marvel Mystery oil and then work the bendix a bit and it should fix it. If the teeth on the bendix or flywheel are damaged obviously that is where the problem lies.
Jul 16, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a 2006 cub cadet LT1050 lawn tractor with a Kohler SV720 engine. It will not turn over, I put a 200 amp jump on starter barely turns over, took plugs out turns over good. thought maybe exhaust valve...
Check oil level. If needle/float in carb stick gas can trickle down into crankcase and cause a condition like you listed. I would also check valve lash. If all these are good, check all grounds and connections, grounds, starter, solenoid. Clean all contacts with wire brush or emery cloth, could be electrical. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 12, 2013 | Cub Cadet Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Garden Logo
1,415 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
