Question about Mag Innovision Computers & Internet
I need the cable fo my mag lt1919wd6 monitor - Mag Innovision Computers & Internet
    Problem Solver:
  • 8 Answers
I recommend you email parts@maginnovision.com (Parts). They should be able to help you.
Good Luck!
Posted on May 07, 2010
I need a driver i think for my mag lt456s monitor i hook it up to computer and i get no power or anything
first check the power cable connection at both end i.e. source of power and also at monitor side if loosen one tight it or may try to change the cable
Sep 06, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Apr 12, 2009 | Mag Innovision Computers & Internet
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
1)red
2)green
3)blue
4)gnd
5)gnd
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
13)Hsync
14)Vsync
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
MAG monitor
The first things that comes to mind is a cable problem. Check to see if there is a bent pin on the graphics cable. Is this a new problem? Did it work before?
Sep 19, 2008 | Computers & Internet
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Monitor
Check the video cable at both ends to make sure it is connected properly.
Move the cable around near the ends and chances are it will look normal. If so then you have a broken wire inside the video cable. A common thing and easy to get another cable.
Apr 03, 2008 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
65 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
