Question about VIA (CX-VT6421A) (CX-VT6421A) IDE Controller
Discontinue access to my hard drive with the via vt6421 card
I have a problem with my via vt6421 card. I use it to contact my hardrive with my motherboard. I experience that I do not have continous access to my datas on hardrive. For example in case of copiing a file from this hardrive to an other in the Total Commander thae process stops for some seconds, then it starts again, then it stops. Or in case of watching video files it stops playing in every 3-5 minutes, then it works again and so on. But if I watch a film that is on my other hardrive it works good.
How can I test if there is problem with the card or not? I have allready checked the cables.
Thanks in advance!
Gábor
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Sudden Hard Drive stop
Your hard drive may be intermittenly faulty, any abnormal sounds from a hard drive is not good. I would connect your hard drive to an USB adapter and plug it into a working computer's USB port and do a Disk cleanup and defrag, if possible run disk diagnostic program on the hard drive. If the hard drive proved OK then you may have a faulty IDE controller or faulty IDE cable, check the BIOS battery voltage, may need a new one.
Posted on Dec 02, 2008
Why the hardrive was wobbling while spinning and i can not access the hardrive?
Friend it is might just get corrupted or brocken check it quickly change it. This brocken hard drive can harm your system, what ever you do do it quickly.
Aug 26, 2014 | Western Digital HDD WD2002FAEX Caviar 2TB...
How to retrieve files from a hardrive on laptop that will not work
One way to do it would be first remove the hard drive:
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52faq4.shtml
Then use a hard drive dock such as this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071) to connect via USB to a working computer where you'll be able to access your files.
Jan 13, 2012 | Computers & Internet
My computer can no longer recognize my WDBAAU0015HBK, western digital portable hardrive. I have tried everything swapping computers, USB cable, etc. All I want now is to return this hardrive (RMA) to WD...
DID YOU TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT, ENLARGE THE PAGE , LOOK FOR YOUR DRIVE, RIGHT CLICK YOUR DRIVE AND MARK PARTITION AS ACTIVE. ....HOPE THIS HELPS.......JEFFXC
Feb 08, 2011 | Western Digital WD Elements Desktop...
Problem using VT6421 card as extra IDE port. I
First, you have to know if all driver components is installed in your computer, I'm talking about your motherboard make sure that all the drivers is installed.
View the status of your device driver.
If you are using Windows base Operating system like Windows XP open this menu:
Start Menu > Control Panel > System icon > go to Hardware tab > click Device Manager
Look for the question mark, it indicates a not working device.
VT6421 is a Serial Raid Controller
http://www.via.com.tw/en/products/peripherals/serial-ata_raid/vt6421/
Refer to the product specification of your motherboard, view this site:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2314
Download and install the Device driver for The Raid Controller of your Motherboard
Jan 13, 2010 | Intel Motherboard
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
Can't access internal hard drive
check if hardrive is dammaged or connected right if not get a new hardrive or if you have xbox live recover gamertag. good luck man or lady! lol
Oct 18, 2008 | Microsoft Xbox 360 Console
External hardrive problem
try do access it with a version of linux. linux is a free operating system.
Aug 04, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
VIA (CX-VT6421A) (CX-VT6421A) IDE Controller Logo
145 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
