Remove fuser locks - Computers & Internet
  • 807 Answers
Whats a fuser lock?
Posted on Mar 27, 2008
How do I change out the fuser fixing unit on a Kyocera FS3900 DN
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the
fuser lock (gray colored) on the rear unit and
the fuser unit is separated from the rear unit
(rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all
the removed parts.
Place the fuser unit on the rear unit (rails)
and push the fuser lock so that the fuser
lock catches the fuser unit.
Do it for the both ends of the fuser unit.
Aug 08, 2014 | Kyocera Mita FS3900DN Fuser Fixing Unit -...
We were getting fuser error 59. We have tried to get a new fuser assembly but all they send us is the film. Is that what we need for this error? How do you replace it.
Fuser Error means that the device has experienced an internal hardware error.
1.Turn the device off and disconnect the power cord
2.Remove the fuser and then wait at least 20 minutes
3.Rotate the locks on the fuser to the unlocked position,grab the fuser handle and pull the fuser assembly from the device.
4.Using both hands, slow and steadily remove any paper or print media from the device and carefully re-insert the fuser and secure the locks.
CAUTION: The Parts on the internal surface of the fuser are very hot, so to avoid burning yourself,please do not touch those parts.
Reconnect the power cable, turn on your device and wait for it to initialize. If the error persist, Change the fuser assembly or contact HP Customer care. This instructions can also be found n your user manual. i hopes this helps.
Thanks
Sep 13, 2011 | HP LaserJet 2840 All-In-One Printer
My printer will not work it gives me system error 000
To resolve the issue, please try reseating the fixing assembly. To do so, please follow the instructions below:
1) Unplug the power cord from the wall outlet.
Caution: The fuser unit and surrounding area can become extremely hot during operation. Perform the following procedure after the fuser unit has cooled down completely. Touching the fuser unit when it is still hot may result in burns. skumar_sreen_0.gif
2) Turn the lock release levers located on the back of the machine in the direction of the arrow and release the lock. skumar_sreen_1.gif
Caution: The fuser unit weighs approximately 3.3 lb (1.5 kg), and it is heavier on the back side. Be sure to hold the grip securely when carrying a fuser unit. Dropping the unit may result in personal injuries. skumar_sreen_3.gif
4) Hold the grip on the fuser unit and install it securely. skumar_sreen_4.gif
5) Lock the fuser unit by turning the two lock release levers in the direction of the arrow. skumar_sreen_5.gif
6) Connect the power cord and all interface cables.
7) Plug the power cord in the wall outlet to turn on the machine.
Aug 30, 2011 | Laser Canon imageCLASS 8180C Multifunction...
50.2 fuser error on HP printer 2840. Received this error, change the toner Q3964A for new one but still having same error code. Tried turning off and waiting 10 minutes and trying again but still same...
  1. Turn off the device, and then disconnect the power cord.
  2. Remove the fuser and then wait at least 20 minutes. To do so, complete the following step
  3. Turn off the device, and then disconnect the power cable.
  4. Rotate the locks on the fuser to the unlocked position, On the rear of the printer.
Grasp the fuser handle and pull the fuser assembly from the device, .
CAUTION: The parts on the internal surface of the fuser are very hot. To avoid being burned, do not touch those parts.
Using both hands, slowly and steadily remove any print media from inside the device. Then, carefully reinsert the fuser and secure the locks.
  1. Reconnect the power cable, and then turn on the device.
  2. Wait for the device to initialize.
  3. If the error persists, replace the fuser assembly.
Jul 07, 2011 | HP LaserJet 2840 Printer
Error 010-297 restart printer
Hi belljohnson5,
The code is caused by a small switch under the fuser unit not sensing the fuser unit is in place. The blue plastic locking tab on the left side of the fuser has a small catch on the bottom of the fuser. The catch is supposed to slip thru a space in the steel plate under the fuser unit and secure the fuser in place. As the catch slides forward under the steel plate, it pushes on the trigger of the sensing switch, closing the sensing switch and letting the copier know that the fuser is in place. (there is also a similar locking tab on the right of the fuser but it doesn't trigger a sensor like the left one does) 1) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier! 2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear.. 3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed. At this point, you should buy another fuser unit or take your copier to an authorized Dell repair center.
Hope this helps.
Thank you for using FixYa.
May 05, 2010 | Dell 3100cn Laser Printer
The printer is on and when I send documents to
Error 928 is generated by the "Engine" board that controls all of the motors, clutches and sensors in the printer. It indicates a Fuser lock motor error usually caused by the Fuser or Fuser motor not rotating. First step is to remove and inspect the fuser. This is at the rear of the printer, has a blue lock lever on both sides and lifts out. Any damage to the rollers can cause it to jam or if there is a sheet of paper wrapped around a roller. be careful when removing a fuser as these can be extremely hot, follow the instructions in the documentation that came with your printer to remove the Fuser.
Nov 01, 2009 | OKI C5500n Printer
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
I have a small peice of paper stuck in the fuser unit of a samsung CLX 3160- How do I remove the fuser to get it out? I removed the 4 screws holding it in, but it is attached somewhere else, is there a...
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Jul 13, 2009 | Samsung CLX-3160 All-In-One Laser Printer
E002 error
First of all to troubleshoot this problem, please reseat the fixing assembly. To do this, please follow the steps below:
Reseating the Fixing Assembly
  1. Unplug the power cord from the wall outlet.
  2. Turn the lock release levers located on the back of the machine in the direction of the arrow and release the lock.
  3. Hold the grip on the fuser unit and remove it.
  4. Hold the grip on the fuser unit and install it securely.
  5. Lock the fuser unit by turning the two lock release levers in the direction of the arrow.
  6. Connect the power cord and all interface cables.
  7. Plug the power cord in the wall outlet to turn on the machine.
Jan 15, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Xerox Phaser 6250 fuser issue
I was stressing out to change the fuser. But, your directions were as simple as A-B-C. Thanks a lot!!!! It worked
Sep 02, 2007 | Xerox Phaser 6250DP Laser Printer
Computers & Internet Logo
David Payne
David Payne
