Question about ION Audio iTTUSB Turntable
Turntable turns at variable rate - ION Audio iTTUSB Turntable
    Guru:
  • 256 Answers
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Posted on Aug 18, 2010
Just bought an Anders all in one player. The 33 1/3 speed is slightly slower. Cannot seem to get it to run correctly. any ideas?
If it is a fairly cheap unit there may not be an area where you can adjust the speed of the turn table
on better machines there is a variable rheostat where by you can adjust turntable speed
quality machines will have the edge if the turntable marked with what looks like bars
This is not decoration but when viewed under a light bulb will appear as stationary bars when running at the correct speed or as a blur when at the incorrect speed
It works like this
the bars are in effect a strobe that is affected by the light frequency or power hz so that when the strobe affect is exact the bars appear stationary
( like disco strobe )
so if your player has these bars on the edge , then check the actual speed with a bulb light Remember stopped bars is exact speed
If the turntable doesn't have these bars then most good home entertainment shops will have a paper plate that can be put on the turn table and the effect will be the same
other than that talk with a good radio repairer shop and have the variable control installed in the power circuit for the turntable motor .
Jul 23, 2015 | Audio Players & Recorders
When i turn my 1210s on both 33/45 switces come on and platter spins too fast
Couple of options , but first cleanen the pithfader and variable resistor pitch vr3 i thought, it's an open one , he needs allways to be replaced, even technics says so and first clean the board, inside and on youtube and this side there enough movies and text how to do it, and check the pitchfader cables very good.
Apr 12, 2014 | Technics SL-1200MK2 Turntable
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
YAMAHA P-220 VINYL RECORDTURNTABLE SPEED PROBLEMS:- HOW CAN I
if you open the bottom,there is variable potentiometers for the speed adjustment.you need a strobe reference disc if you want it exact.
Aug 15, 2009 | Audio Players & Recorders
Daytron All in one Turntable, 8-track & fm
if the turntable is belt driven.... try replacing it... maybe the belt is worned out
Jul 19, 2009 | Audio Players & Recorders
The 5500 doesn't recognize the files on my ipod, which are mainly cd's impoted to itunes, so i converted all the files to MP3 but it still isn't recognizing the files. what do i do?
Actually there are 2 possible solutions to your problem. When you plug in your Ipod or USB drive into the Denon HS5500 the machine will put a file on the drive called "Denon_DJ". This file needs to be deleted each time you add new mp3's to your ipod or usb device or your new files wont be shown.
The second has to do with what type of mp3 you are using and what sample rate it was created with.
For instance I record music with my computer and keyboards. I like to record in 96KHZ because it sounds so much nicer than 44.1k. Well the Denon wont read anything created with a sample rate higher than 44.1K . I downloaded a song from a DJ friend that was recorded in 48KHZ and made into a 196k MP3 file. The Denon wouldn't play it because it is not 44.1. Check your manual or check online.. the Denon reads 44.1k 320kbs and lower files only.. (Bad Denon)
You may also want to avoid what are called Variable Bit Rate files. Most files you download online are ripped at a variable bit rate. The Denon will play variable bit rate Mp3's .. But you will not be able to save cue points or save memos to the system. I found this out the hard way. So. I took all the files I had created that were VBR and put them into Audacity with the Lame MP3 plugin and set the bitrate to 320kbs and now I can save memos.. But everytime I put the USB flash drive into my pc and put new songs on I have to delete the Denon_DJ folder.. Its sad too because thats where the HS5500 stores it's playlist files... :( Bad Denon. They should have asked me to write the software.. xD
I hope that helped you..
Apr 12, 2009 | Denon DN-HS5500 Turntable
Speed regulator.
First and foremost, are you located in the U.S.? If so, make sure your unit's voltage is set to 115V rating. The switch is located under the turntable platter. All you need is a flat head screwdriver to turn it to the proper voltage. If it's on 220V, you need to change it. If you are not in the U.S., or it is already set @ the proper voltage rating, your problem could be one or many issues with the drive, and pitch control. There are various resistors, capacitors, IC's and variable resistors, which control the drive. Any one of these could have gone bad on you. Do you have a runaway operation, or is it doing that back and forth movement? In either case, this cannot be self repaired, and you will have to take it to a qualified service center for repair. Cost will run you anywhere from $60-120 - if they go higher than that, they either do not know what they are doing, or they are trying to pull one over on you. We work on these on a daily basis, and should cost you more than that. However, prices do depend on where you live (we are in NYC). Good luck!
Sep 08, 2007 | Technics SL-1210MK5 Turntable
ION Audio iTTUSB Turntable Logo
62 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
