Question about Max American Terminal 30 i Fuses
Cannot locate ac fuse possible needs to be replaced air is only blowing hot. sealed and added cub zero
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Under driver side dash, i think it also depends on what kind of car you are driving. Thier is also a fuses panel by the battery (most of the time) under the hood. On my caddy thats where the ac fuse was located
Posted on May 12, 2010
Why ac blowing hot air
start off with the cheap possibilities and make your way threw.
I'd start off with replacing Air Charge temperature sensor, make sure your AC Hose isnt leaking anywhere, if those dont solve it then replace ur AC clutch, last chance would be replacing AC compressor. sometimes the compressor will malfunction randomly. or the AC clutch might malfunction aswell. covering these steps somewhere along the line you will have working AC again! good luck
May 18, 2013 | Volvo V70 Cars & Trucks
2004 VW Passat AC is blowing hot air
Have the dealer check to see if the AC compressor cycling switch is stuck.
Jun 14, 2012 | Cars & Trucks
2001gti vr6 ac not working. Blowing hot air. Is it posible bad module?
First check the ac fuse, if it is ok check to see if the clutch is turning when the ac switch is turned on. If clutch does not engage you should check the ac relay. It is usually located in the fuse box. You can switch places with it and another relay with the same number in the box. If compressor still doesn't run it may need to be charged with R134. If compressor runs for a few seconds and shuts off and continues doing this with control on high. It nees more refrigerant added.
Aug 08, 2011 | 2001 Volkswagen GTI
I have a 1999 dodge ram v8 5.2L the ac accumulator was replace after the truck has been setting for about 4 yrs replaced the vacuum lines which as well as the gaskets i added about 2 and a half cans of...
you may have over filled the ac with reon and are over pressuring the system causing the high pressure switch to activate shutting off the ac, each can is 1lb
Aug 20, 2010 | 1999 Dodge Ram
2000 lincoln ls ac blowing hot air I've replaced the heater control valve
You need a scanner to diagnose,not a code reader.
The DATC Module ( Dual Automatic Temperature Control Module) is a possible
May 21, 2010 | 2004 Lincoln LS
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
Cub Cadet zero turn mower quits mowing, service center says clutch is fine but can't find anything wrong. Put 30 amp fuses in and they will blow after about 30 minutes of mowing. Any suggestions
when the fuse blows check for hot wires it seems to have a short somewhere hardist thing to find. look for naked spots on wires or pinched wires .
Oct 21, 2009 | Garden
Jeep Wrangler 03 A/C stopped working abruptly
This may be the AC compressor cycling switch is defective. It is located in the larger of the 2 AC lines coming from the compressor, it has a wire connector to it with 2-3 wires. To verify this is the issue jumper the connector with a small piece of wire and see if the compressor runs.
Nov 20, 2008 | 2003 Jeep Wrangler
Max American Terminal  30 i Fuses  Logo
65 people viewed this question
Top Max Car Audio & Video Experts
Don Malinowski
Don Malinowski
Level 1 Expert
Richard Warren
Richard Warren
Are you a Max Car Audio and Video Expert? Answer questions, earn points and help others
