Question about Frigidaire ATF6000ES Front Load Washer
Washer won't start
There is no power coming to the washer. It will not turn on ( light will not come on).
  • 1 more comment
  • bearncapone Jun 15, 2008
    My front load Frigidaire washer will not come on either. No lights, no power, nothing. I've checked the circuit breaker, replugged using a different socket and still nothing. It is only a year old with minimal use. There was a major storm in our area this past week and power was out for several hours. Could this have anything to do with this problem? Any suggestions would be greatly appreciated.
  • Anonymous Sep 24, 2008
    I have the same problem only with an LG WM2077CW
    Power to the outlet but the machine will not turn on
    Yes, I've checked the outlet with another appliance, yes I've shut the machine off overnight, I'm told this machine does not have any fuses
    Could it be the power board
  • Gary Davd
    Gary Davd May 11, 2010
    do you have power at the plug?? have you tried to plug in a lamp there to see if it is ok?? let me know and we will move on from there
  • 30 Answers
Check for power at the terminals and the plug. If the plug and or terminals are discolored, broken, and you have no continuity-replace the power cord, or terminals or both. After a power surge, or lighting these could become burn or broken, and therefore power could be lose.
Posted on Sep 03, 2008
SOURCE:
I have a LG steam washer 4.2 cu. ft. that the display doesn't come on but has tub light on why doesn't display come on?
have you heard beep when you turn it on? if not washer is off. If it won't turn on could be the power button(or main baord). Compare the touch of power button with the other buttons. Light on means you have power coming to the washer. Thx
Mar 01, 2014 | LG WM-2277HW Front Load Washer
No power to my kenmore dishwasher
check the power circuit to the washer
Dec 21, 2013 | Kenmore Kitchen Ranges
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Frigidaire ATF6000ES Front Load Washer Logo
143 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
