The repair of a dual cassette deck is usually not worth it if you are paying a Technician but since you are doing it yourself, there are screws that must come out of the deck to take the transport out. Some of them require you to take the plastic door off. They are not a treat to work on and often even when you are done they have poor performance anyway. Where the belt goes is indicated on the pictorial diagrams of the service manual. Otherwise it is common sense and a little bit of physics. I have probably done 400 by now. Maybe some TV shops will work on it but they are really not real Technicians for tape decks and most times hacks.
I do not mean to sound uppity but the changing of the belts will also require the oiling of the bearings and speed adjustment calibration as well as many other tests. You should send or take it to a qualified Technician who has all this equipment- I do it 14 hours a day still.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
This is something I can tell you that you can sort out yourself with a little bit of mechanical aptitude and a couple of screwdrivers.
FIRST turn the power off to the unit.
If you pop the lid off the unit, you will see that the capstan drive belts to the tape decks mechanism have failed, Either turned to back muck like windscreen sealant, or just broken and dropped off. The belts (each deck has one) will need to be replaced. The part number for the belt(according to my records) is REB1272 You should still be able to get them from Pioneer spares directly in your country. Let me know where you are and I can get some better information to you.
good luck. Happy to assist you further and answer any questions you may have.
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
