Question about GE JKP15 Electric Single Oven
Oven not working after self cleaning
Used the self cleaning function on my oven, now it is locked and acting like it is not working at all.
  • GE Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 07, 2010
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
Jun 22, 2012 | Hotpoint Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
While attempting to use the self clean the door lock indicator came on then F9 followed by a continuous beeping, i've tried unpluging it but that did'nt solve the problem. What should i do?
Whenever the self clean function is activated, this lock the doors for up to 8 hours on some models.
This is because to clean, the oven heats up to over 800 degrees, and the door locks for safety, until the unit cools down to what is considered a safe temperature, many oven fail after the clean function is used, as often the temperature sensor fails, along with the thermostat, this lock the doors, often when faulty.
First thing to try is to reset, (Recycle the breaker switch) the breaker, if that doesn't work, than it's either DIY, or call a serviceman, (recommended).
Feb 01, 2011 | Ovens
Oven door lock is stuck locked. Using self cleaning function and now door won't open. Is there a trick to it.
If the oven is finished with the self cleaning cycle and cooled down, it should automatically unlock the door.If it doesn"t, try unplugging the oven to see if that will reset
Jan 09, 2011 | Ovens
Upper oven will not self clean. The door lock does not actuate when self clean is selected. All other functions seem to work OK
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE Profile JKP56 Electric Double Oven
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Self Clean does not work
heatman101
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
GE JKP15 Electric Single Oven Logo
148 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
