Question about Mtd Troy-Bilt Bronco OHV Tiller
Troy-bilt bronco leaks gas from the air filter hopusing. How can i fix this?
  • 3 Answers
Leaking gas through the air filter ports can only mean excessive gas flow from the carburator. Try adjusting the flow screws on the carburator bowl. Check all gaskets, seals, etc. and happy tilling!
Posted on May 06, 2010
I have this exact problem also. I have found, in my situation, that the float bowl has developed a pinhole in it, allowing it to fill partially with gas. Simply put, bowl gets heavy doesn't float, gas doesn't get shut off and gas comes out of the air filter. My problem developed because I normallly run all gas out of tank before I store it for the winter. The brass float came in contact with the aluminum bowl housing and badda bing badda boom, electrolysis in action! I was able to repair the bowl housing with some 2-part epoxy, but I will have to replace the brass float.
Posted on May 17, 2012
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
May 27, 2014 | Troy bilt Super Bronco Tiller 208cc
Gas floods into carburetor even with a new carburetor
The only thing that stops gas going into the carb is the needle valve and seat in the bowl of the carb.
Doing the same thing with 2 different carbs sounds like trash in the gas tank flowed into the carb and is holding the needle valve off the seat allowing gas to flow all the time.
Clean the tank. Clean the trash out of the needle valve/seat. Add a small engine fuel filter between the tank and carb.
You should be good to go.
Oct 07, 2017 | Troy-Bilt Troy Bilt Bronco CRT Garden...
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
Troy bilt mower ran fine then died and now it wont start back. It has fire and a new spark plug. It gets fuel past the filter. It starts if i put a small amount of gas into the intake. Whats wrong? My...
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Jun 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
What motor oil does the troy bilt bronco use
10w-30 should work.it should say what oil to use on it
May 27, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Mtd Troy-Bilt Bronco OHV Tiller  Logo
594 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
