Question about Sewing Machines
Need to adjust bobbin tension - Sewing Machines
    Genius:
  • 1,116 Answers
Righty, thighty - kefty loosey.
Mark the **** in the screw head and surface on the side of the bobbin case with nail polish so you know where you started.
Posted on May 06, 2010
  • 21 Answers
Turn the small screw on the bobbin holder.clockwise to tighten and anti clockwise to loosen.
4 Suggested Answers
SOURCE: Adjusting Bobbin Tension
I looked forever to find this darn green bobbin screw. Around the opening for your bobbin is a plastic cover. If you slide it forward it will pop right off. Once you remove this, the bobbin case will lift right out. On the front you will see your green screw for adjusting your bobbin tension.
Posted on Sep 25, 2008
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
bargainbox
  • 1388 Answers
SOURCE: janome 9500 bobbin tension too tight can I adjust it
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on May 01, 2009
My bobbin thread is showing through on front please help
Loosen your top tension. If it is too tight, it will pull the bobbin thread to the top of the fabric. If it continues, then it may have to do with the thread weight you are using in the bobbin or the bobbin tension needs to tightened slightly. HOWEVER, adjusting the bobbin tension is usually a last attempt. It is a sensitive adjustment.
I frequently use a lighter weight thread for quilting and need to adjust the bobbin tension. So, I have a separate bobbin case that is adjusted for that purpose only. Having to adjust the bobbin tension every time one changes the thread weight is a real pain. For most general sewing, the factory set bobbin tension should be sufficient.
Understanding Thread Tension Threads
Nov 09, 2017 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
How do I adjust tension on the bobbin?
First of all, be absolutely certain that the problems being experienced are not a result of the upper thread tension, ie threading when the presser foot is not in the up position, thread pathway is correct, a brand-new needle compatible with the thread and fabric, etc.
Before making any adjustments to the bobbin tension, be sure to mark the bobbin case where the skrew slot sets with permanent marker or a small drop of nail polish. This will allow you to reset it to original should your adjustments not be successful. And, make only minor movements of the tension adjustment, ie 1/8th of a turn, then re-test, before making another adjustment. Tiny incremental changes will make a huge difference in the outcome.
Understanding Bobbin Tension
Bobbin Tension How and Why Tension is Adjusted
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwiAs_S73ZnMAhUpnoMKHXQjA7cQFgg4MAU&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja
Apr 18, 2016 | Sewing Machines
The bobbin thread shows to the front. Does the bobbin or thread tension need adjusted
Generally, tension adjustments are made using the upper thread tension. Most likely the upper tension is set too tight and is pulling the bobbin thread up. Loosen the upper tension and try again. Tension is accurate when the upper thread and bobbin thread meet in the middle of the fabric. Whenever fabric, thread & needle are changed, there may be a need to adjust the upper tension.
HINT: When threading the upper thread, make sure the presser foot is RAISED during threading to make sure the upper tension disks are open and the thread seats properly.
Bobbin tension is only adjusted when the tensions are way out of whack. Only slight turns of the bobbin case tension screw are made in graduated movements and testing occurs after each adjustment.
Jan 20, 2016 | Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
The thread is birdnestting where the bobbin is
Birdnesting can be corrected by adjusting the bobbin tension lower. You need to check for threads stuck in the bobbin tension and clean them out. The thread should feed out of the bobbin tension with a small amount of tension. Make sure your bobbin is rotating the right direction; probably counter clockwise. Adjust the top to three and give it a try. You may need to make a small adjustment on the top tension. Your goal is to have the bottom and top tension equal just like a tug of war.
Jan 22, 2014 | Brother PE-500 Embroidery Machine
Thread is bunching up from bobbin side think tension needs adjusting
I assume you have tried adjusting the top thread tension and are referring to bobbin tension adjustment. Before you do anything, with the bobbin properly threaded, manually pull out some bobbin thread. There should be resistance, just like the resistance you feel when you pull on the top thread with the foot down. Bobbin tension adjustment is by means of a small screw in the bobbin assembly. Mark the screw head position before you start adjusting it (so you can return to that position should you need to). Make small adjustments (1/8 turn of the screw) in each direction and see if it helps the problem. Be aware that thread tension is only one of many problems that can result in faulty stitches.
Nov 25, 2012 | Husqvarna Rose
I need to know how to adjust the bobbin tension on my euro-prox sewing machine.
There is a tiny screw on the side of the bobbin case.
Mark the **** (in the screw head) position on the bobbin case with tiny dab of nail polish so you will know where the original setting was.
Left/loose and right/tight.
If you are adjusting because the bottom stitching is loose/loopy, first try threading the machine with the presser foot up to see if this solves the problem.
May 01, 2010 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
164 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
