Question about Bulova Watch
How to set and turn off the alarm on my sector 540 or how i could get a user manual
Set alarm on sector 550 chronograph alarm saphire crystal
Thanks for help!I love older Sector swiss watches !Those watches were built to last!
Sep 23, 2013 | Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Lost my instructions - how do I set the musicall watch, alarm etc
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals. Rate me, please .
    Apr 06, 2010 | Sector 2653940025 Wrist Watch
    Where can I get an owner's manual for a Sector 133 Chrono Alarm watch?
    As there is no manual downloads possible for SECTOR watches, the only solution is to contact SECTOR directly. Of course you can browse all the internet, but I'm quite sure direct contact will save you nerves, time and money.
    Here is the link:
    http://www.watchservicecenter.it/
    Rate, please.
    Jul 22, 2009 | Sector Watches
    Instruction manual
    Visit this site (paste it into your browser):
    http://www.kenmarwatches.com/sector/mountain-master/
    Find your exact model and ask a question. There are no direct downloads, but you can talk to an online representative, email them questions or ring directly by the phone. They will be happy to give you all the info you are looking for.
    Don't forget to rate, please.
    Jan 13, 2009 | Sector 3251908015 Mountain Master watch
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    Sector adv 1000 setting alarm
    key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
    Apr 14, 2008 | Watches
    Bulova Watch Logo
    292 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
