Question about Magic Chef 31000 Gas Kitchen Range
-FO code indicating
Oven randomly beeps flashing the -FO code
  • 794 Answers
The error code F0 indicates a stucked function key. Just replace the touchpad or if the touchpad is part of the clock, replace the clock (ERC), and you will good to go.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
Keeps shutting off with fo code
The F0 error code indicates that the control board detects a stuck key on the control keypad. This is often caused by a bad control keypad but it can sometimes be caused by a failed electronic control board in the oven console. A technician will normally determine which component is causing the problem by
shutting off the breaker
and unplugging the ribbon wire cable for the control keypad from the electronic oven control board in the console. The oven would then be powered back up to see if the F0 error code returns with this ribbon wire cable disconnected. If it does, then the problem is with the electronic oven control board. If it does not return, then the control key panel will need to be replaced. I normally recommend that you have a service technician repair this type of problem. Here is a link for the Sears Service website:
Sears Home Services
Mar 24, 2016 | Sharp Heating & Cooling
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Hi... While baking the other day my GE oven suddenly started beeping and flashing the error code FO ...Is there some way to resolve this problem without calling in a repair person to fix it? Thank you
Hello & Welcome to FixYa
Error code F0 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Even the beeping sound indicates that it is the board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | Kitchen Ranges
My oven has code Fo displayed. It began with a beeping. We turned off the breaker and turned it on again. The beeping continued. After several attempt the beeping has stopped but the code remains...
Hello, I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Thanks
Jul 14, 2010 | GE JGRP17 Gas Single Oven
FO error code
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
May 06, 2010 | Magic Chef 9122 Gas Single Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
My oven wont quit beeping!
if it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Feb 13, 2009 | Ovens
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Magic Chef 31000 Gas Kitchen Range Logo
94 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
