Question about GE 30 in. Profile JP350 Electric Cooktop
The right front burner will only run on high no matter the setting
    President:
  • 1,430 Answers
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You will need to remove the cook top from the opening to access the switch.You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 06, 2010
Kenmore glass top electric range and the left front burner stays on high no matter what setting its on???
Hi there
Are you sure that the knob that sets the settings is securly fastened?
Or that the electronic have not got confused?
I would think that you should need to have the knob seen to.
all the best
kolbrun
Mar 12, 2012 | Kenmore Cooktops
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
370 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
