Question about HP Bestec ATX-1956D 200w HP Part No 0950-4106 (ATX1956D) Power Supply
Green light only dimly on and computer does not turn on.
  • Ctrlr4repair
    Ctrlr4repair May 11, 2010
    Please identify whether or not this is brand new or a used system. This will help me in figuring out what type of problem it is and what to do with it. So please give me as much detail as possible. Thanks
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Hitachi model# 50ux23ka no power???
The green ones are each tied to a voltage source in the power supply of this set, try to see if one goes off or dim before the others, the red one should always be on.
If one can be seen to go out first or dim first that voltage line is being held down or has a problem.
Its meant to be a way to know which voltages are up and also to narrow down where a problem might be.
Dec 12, 2012 | Televison & Video
I have model 1975NW. When power is turned on, green light appears, then orange light. No picture is present.
The ORANGE light indicates "power-saving" mode -- when no "output" from a video-card is being detected, the screen will dim itself. Try a different monitor. Try a different video-card in your computer. Try your monitor on a different computer.
Feb 03, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
My dashboard light or green background on the odometer side is very dim. How do i lighten up the green background on my 2004 Range Rover HSE???
There should be a dimmer switch like a roller on the dash or connected to the light switch. It may be also in the form of a button you push upwards to brighten and downwards to dim. Let me know how it turns out, The Raz
Apr 17, 2010 | 2004 Land Rover Range Rover
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Will not turn on
This indicates a serious problem either in your power supply or processing board and associated circuits....
Feb 10, 2009 | Samsung HPL5025 50 in. Plasma Television
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
