SOURCE: Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
SOURCE: Won't print InDesign documents or Adobe PDF files
hi,
try to download a new postscript driver and install it instead of using pcl driver!
SOURCE: EPSON Stylus Photo R1800: InDesign CS3 (iMac 10.5.5) colors wrong
You definitely need to use the updated driver for Intel Macs.
SOURCE: text boxes.
There are a few different drivers for this machine: RPCS (ricoh's own), PCL5c, and PCL6. I have had incidents of strange output, often with the RPCS driver, and find that the PCL 5c works best. Identify which you are using, and maybe try another.
here is a link for the driver download page. Copy the line into your web browser:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/c32_38/c32_38en.htm
SOURCE: Got error when print to Xerox phaser color printer
If the printer does not have a hard drive. Pdf will be hard to print.
Second, Are you using a PS driver or PCL? If PCL change to PS.
Here are some direct printing setups also.
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
To download a file to the printer using CWIS:
NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
