Question about Goldstar R1203 Air Conditioner
Compressor not working
First, i'm not sure this is the same model but it matches the picture. everything else is working, but compressor will not start. when in energy saving mode it will try to start, at least the fan does, but shuts off. there is a flashing green light in between cool and dry on control panel. i can not find manuel to see what the light is for. any help would be appreciated.
  • 306 Answers
If you are kinda handy you can check the capacitor the compressor side sounds like from your description is bad. Cheap part to replace in a small place to repair.
Posted on May 06, 2010
I have a 42 inch Panasonic viera comes on sound is there everything works except picture. Sometimes I have lines of color flash on the screen what's going on.
Replace the video cable and make sure your video input is matched properly with the audio (audio on input 1/video on input 1) or whatever input you are using.
Feb 25, 2015 | Panasonic Televison & Video
The muffler is too short for this model. It is 1 ti 1.5 inches from the head or area that it is suppose to screw into. THe picture in the manual show the black housing next to the head. It is not on this...
You should get the correct part, however, these parts have standard pipe threads. Match up the muffler thread with a pipe nipple that is long enough to reach, purchase a matching coupling, all in metal, and install everything, it is worth the few dollars to try.
Gary
Mar 10, 2011 | Clarke Power Products Air Compressor...
I can't find a replacement capacitor for my air compressor.
Hi you have to bring the old capacitor to a electric motor shop so they can match it up or write the name and numbers off the motor and give it to them and I am sure they should be able to match one up.
Mar 10, 2011 | Craftsman Air Tools & Compressors
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Ruud Model UACC-036JA5 Compressor doesn't work
You can get a compressor. I don't know if it will be rebuilt. Has anyone looked at your unit. How do you know the compressor is bad. There are a couple of things to check if it is just not running. To replace the compressor you would need to recover the refrigerant first. Give me some more details on your problem.
Jun 29, 2010 | Ruud Matching Split Air Conditioner
Need replacement R12 refer and freezer compressors. OEM Americold compressors no longer available. URS 48 DT model should also work. Thank you.
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
Dec 30, 2009 | Refrigerators
Broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Nov 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
No picture
If i am to understand this correctly, this is a rear projection television. Inside there may be 1 - 3 " color " control boards that control the picture before going on to the projector. an accumulation of dust / dirt / debris has adverse affects on electronic componants, make sure they are dust free (compressed air cleans them off quite well. If using a home compressor, make sure there is a vapor filter to remove water from the airlines.)
If they are clean, and as you said you recently had the television serviced to replace the projection lamp, take the television back to the repair shop to have them determine the problem.
If you yourself replaced the projection lamp, be sure to check all connections are properly seated if you had to disconnect something, make sure they are in the proper places, and any connections are securely connected.
If all else fails, have a local electronics / television repair person check the unit for faulty componants.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hi i am a refrigeration mechanic and i need a compressor for a chest freezer, here are all the reference numbers on the compressor, can you tell me the specs so i can get a match. SMH 2598133 Model no:...
i think any 1/3 hp 134a compressor will work you just have to make sure the fitting are in the right place,i got mine on ebay for $50 or you can check sears.com(parts) or repair clinic .com,let me know how you do-mike
Oct 28, 2008 | Refrigerators
Frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
May 30, 2008 | Refrigerators
Goldstar R1203 Air Conditioner Logo
172 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
