2001 Daelim VT 125 Evolution Logo
Posted on May 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i was wondering what bulb to put in the headlight and front light as the 12V5W burns out really quickly(2 days) headlight lasts alot longer however not the brightest.
gavin jones
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Daelim Master 1,508 Answers
  • Posted on May 07, 2010
gavin jones
Daelim Master
Level 3:
Renaissance:
Answers
1508
Questions
0
Helped
484480
Points
3349
The wattage shouldnt cause them to blow, the most common reason is vibration, followed by high voltage. check the voltage , should be around 13v running
Last night, I lost my headlights, tail and brake lights. when you turn on either turn signal, the front flashes and both rear turn signals and brake light flash all at the same time. any clue? @
Hi, Anonymous if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your headlight bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to the headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.twtex.com/forums/threads/2009-fat-bob-fxdf-electrical-issue.94756/
http://www.mediafire.com/file/y8au34oc778d7oc/2009_Harley_Dyna_Service_Manual.pdf/file
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/fat-bob-2009-owners-manual-66578
https://www.6ya.com/
HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Top Daelim Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Daelim Expert? Answer questions, earn points and help others
