Our jam-proof 460ci (which we've had for 10 months) appears to be jammed; none of the lights are coming on, including the power light. we've moved it to other plugs to test. no luck. There is paper in it partially shredded -- but only 7 sheets. Thanks, Judy
  • jsoslau May 06, 2010
    It's a Fellowes. Thanks.
  • 86 Answers
What brand is the shredder i can possibly help with a little more info . I fix machines for a living and shredders too. Hope to here frome you.
Posted on May 06, 2010
  • soopsnoop May 07, 2010
    In most fellows shredders there is a fuse inside. Also this shredder may have a breaker on the back if so it will look like a black button or pin sticking out if there is while power is turned on and machine is plugged in push and hold that breaker in for about a minute then let go .If that was the problem the machine will come back on. If this does not help write back and i will investigate further. Hope this helps.
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
I am receiving a printer error C000 what does mean? I've tried everything... help!
Suggestions from my recent encounter with this error:
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
when inserting cartridges tilt them forward and down so they go under the plastic lip then seat the rear so that the light comes on.
Please rate my help++++Thanks for using FIXYA
Dec 01, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My hp 1040 constantly jams have tried to clean it and makes little or no difference any suggestions. It will print half of a page then it will say that it is jamed.
>first try to power reset the fax machine, then see if the error still persist..to to a power reset unplug power cord from the back and wall outlet then wait 30 sec and then plug it back
>if the error still persist open the the rear access door and check the if there is any jammed paper in there.using a lint free cloth lightly moistened with distilled water wipe the rollers clean. also check if there is a paper jam from the inside of the printer by opening the cartridge access door
>If there is no paper jam and it gives you a paper jam error message then try to check if the carriage can move freely, first while the printer is on open the cartridge access door of printer cover, the carriage will move to the center which will give you access on it, now unplug power cord from the back of printer with out pressing the power button off. try to check if there is any debris or paper that is blocking the carriage path. with your fingers try also to move the carriage from left to right and see if it can move freely. if the carriage can not move then you have a carriage jam which causes also the paper to jam, if it can move freely then try printing and see if it will jam again.
>also try to remove and reseat the ink cartridge.
>if this will not resolve the issue try a hardware reset, while the fax is on unplug the power cord from the back with out turning it off. press and hold # and 6 at the same time.while holding the buttons plug back the power cord and wait till you see semi-full or nvn reset when it turns back on then release the buttons. if the machine will not automatically power back on press the power button. it should ask for you to select language, region etc a proof that you have successfully done the reset..try printing...
>if it jams again contact hp and ask for replacement if it is still in warranty if its not ask for an upgrade
Sep 21, 2009 | HP 1040 Plain Paper Inkjet Fax
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
53 people viewed this question
k24674
