Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Power supply whats the highest power supply that i can use for this motherboard foxconn g33m02 currently using 300w wanted to know if i can go higher like 450w
    Scholar:
  • 91 Answers
Well really it doesn't matter to an extent, because you can easily upgrade you powersupply to something bigger and not worry about it aslong as it has the right connections for your motherboard (most are all the same and work for about any motherboard but there are some funny ones) just read the specifications on the power supply and see what type of cords are included and how many. The power in your power supply really just means how much your pc can handle at once, for instance i run ATI Crossfire with 2 really powerful graphics cards and the minimum required power supply amount is 500w so to be safe I'd get one of 550 or 600 incase I had some other really powerful hardware that would need to use it.
Posted on May 06, 2010
  • 174 Answers
You can go as high as you want. Typically the higher the wattage, the more devices you can add as motherboard inputs are standardized so it won't make a bit of difference to the motherboard just so long as you stick with ATX power supplies. So you could go to 650w or even more and it won't make a difference, although you won't need that much wattage unless you have lots of drives and a power hunger discrete graphics card.
Manual for Foxconn G33M02
Hi you can find the manual here
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket775/G33M/manual/Easy%20Guide/%283A2505E00-000-G%29-G33M_easyguide.pdf
Feb 06, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
How to activate the VGA monitor port on motherboard Foxconn g33m02?
You need to use DVI to VGA convertor but mostly it is recommended to use a dvi compatible monitor. VGA wont work. Im pretty positive
Feb 01, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
Diagram of foxconn g33m02 motherboard
hi good day I have a problem with my pc mother board model Foxconn G33M02 the problem is on and off in every second can you help me how to find the excact or to point the problem thanks
Feb 16, 2012 | Computers & Internet
Dell Inspiron 530 - Plug it in, immediately powers up, PS fan and Video card fan start, power button shows amber light and does not turn off power, motherboard shows amber light instead of green;...
Hi
This seems like a power management problem on the motherboard.
Disconnect the power cable. Remove the small silver CMOS battery for 2 minutes to clear the BIOS Memory. Reinstall the battery and reconnect the power.
Look carefully at the power lines coming from the Power Supply Unit (PSU) and make sure that no one power channel is powering an unequal load of devices. Try and divide the load as evenly as possible amonst the power lines.
If none of this solves the problem, then consider upgrading the fitted 300W PSU to one with a higher Wattage, as 300W is on the low side for current standards. 450W-500W is more typical nowadays. The higher the Wattage you can afford (up to a 650W maximum for this particular specification of PC) the better
A higher wattage PSU will work well within its capacity and therefore under less strain than the current one. The symptoms you describe could be signs of the current PSU straining at the limits of its performance range to power all the devices inside as well as maintaining the computer's heavy workload of interaction with all the devices connected to it.
I hope this helps.
Aug 26, 2011 | Dell Inspiron 530 Desktop Computer
I WOULD LIKE TO KNOW IF I CAN USE A 300W POWER SUPPLY UNIT FOR THIS ASUS K8V*MX
The wattage rating is the maximum power draw that the power supply can supply. If the system only requires 200W, only 200W will be delivered by the power supply. It is recommended that the power supply rating be higher than what you expect to draw so that you never draw more than 80% of the total capacity. In other words, if you expect to draw 240W total, use a 300W power supply.
So, yes it is fine.
Dan
Jan 13, 2010 | ASUS K8V-MX Motherboard
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
From 300w psu i change it to 450w will that be ok?
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Jul 11, 2007 | Jackson 25 in. TempStar HH Free-standing...
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
255 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
