Question about Kenmore 9296x Top Load Stacked Washer / Dryer
Need an exployed veiw of dryer some one has taken off some parts it is a kenmore elite stack 92964100
    President:
  • 1,937 Answers
A two part process based on the number you provided.:
First, go to the following site and select which of the three (or more) complete model numbers you have.
http://www.managemylife.com/mmh/owner_manuals/search?query=92964100
Then, using the full model number, go to the following site for complete diagrams / parts .
http://www.searspartsdirect.com/partsdirect/index.action
Posted on May 06, 2010
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Want to know if I can stack a kenmore elit gas dryer on a kenmore elite washer and on top of a 10 inch pedistal or will it be too tall?
The appliances were not designed to be stacked so I would not attempt it if anything I would build a shelf (ledge) to put the dryer on, then bracket it to the wall but be careful of the height especially with a gas dryer and be sure to have plenty of space for airflow. Good luck
Mar 27, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I need instructions on stacking kenmore washer and dryer
You should be able to get this information from Sears as part of the installation instructions
Jan 06, 2013 | Kenmore Washing Machines
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
My dryer smells like burnned its an elite kenmore oasis and it doesnt dry very good
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
I have an elite kenmore dryer and it doesnt dry and it smells like burnned
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I need help putting my dryer back together
Here is a couple of websites that shows the breakdown and parts of dryers, maybe they will have your model to help show where the two springs go.
http://www.appliancepartspros.com/index.aspx
You could also try this website.
http://www.partselect.com/
Good luck,
I hope this helps
Oct 06, 2009 | Kenmore 67082 Electric Dryer
Want to stack my Kenmore HE4 Dryer on top of my Kenmore HE3t W/M
When you originally ordered the dryer, it should've come with a stacking kit that is compatible with the HE 3T or HE 4T washer. It is basically a foam piece that goes on each side of the washer, and then the dryer is connected to it from the side. If you do not have this piece, it should be available to order if you visit http://www.searspartsdirect.com Just enter the model number from your dryer (inside the door frame) and it should pull up a parts list. Or just try searching for a stacking kit for Kenmore dryer. Hope this helps.
May 18, 2009 | Kenmore Elite HE4 Electric Dryer
Very loud after stacking.
I assume you used the kit for stacking and removing the top of the washer and installing the plates?
You might need some sticky rubber pads to stop metal to metal contact and some duct tape around the vent exiting the dryer where it meets its back panel. This is common, you could go specific or browse ace hardware and find a compatible source.
Sep 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 9296x Top Load Stacked Washer / Dryer Logo
70 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
