Sony tv mfm ht75w tv doesn't stay on, works for 10min sometimes,, other times only sec. i opened it all the caps seem ok, any ideas
Sony tv mfm ht75w tv displace with white line and unclear picture
Posted on May 31, 2012
  • 4,889 Answers
Please clarify whether the entire tv powers off or only the screen turns off and you can hear the sound so that we can continue with the diagnosis. Sony LCDs are notorious for backlight inverter failures.
Posted on May 06, 2010
  • eagle338
    eagle338 May 07, 2010
    That does sound like a backlight inverter board failure. I have one more small diagnostic for you to confirm. Do you see a dull glow on the tv when the screen goes blank? If it does not then its time to get a new backlight inverter board and that will resolve the issue.
    Sai.
How do i switch off mute on sony mfm-ht95 without remote
Press the volume + or - key from TV local control Panel
Sep 30, 2013 | Sony MFM-HT95 19 in. HDTV-Ready LCD...
Droped my Sony MFM-HT95 19 in. TV
Hi Leonardzap
Can you advise if you found a solution to this problem as I too have this screen and it is cracked
thanks
Feb 24, 2009 | Sony MFM-HT95 19 in. HDTV-Ready LCD...
Sony mfm-ht75w no speaker sound when in computer mode
go into your computer and find the speaker control
it may be turned off or reseted
Jan 31, 2009 | Labtec LCS 1040 Computer Speakers
Does Sony MFM-HT75W LCD TV need a HD converter?
Sony style has an e-support system that provided the information I needed. It was obviously FREE!
Nov 22, 2008 | Sony MFM-HT75W 17 in. HD-Ready LCD...
Monitor - No Signal
I am assuming that you are referring to the same monitor working only if the PC is in Safe Mode but not in Regular Mode.
This is possibly due to the Screen Resolution and/or the Refresh Rate Settings of your Video Card to way too high for the monitor. While in Safe Mode lower these settings in your Display Properties.
.Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 03, 2008 | Sony MFM-HT75W 17 in. HD-Ready LCD...
Sony MFM-HT75W 17in Multifunction Display
Hi, I was able to fix my set by changing only three out of the six capacitors between the heat sinks opposite the plug on the board. I noticed under a microscope the caps looked a little puffy, but not much, and I checked them with a capacitance meter, but they were in tolerance, but decided to change the three closes to the edge of the board with a 1000uf, 50v, 1000uf 25v and 1000uf, 50v with the one that is 25v going in the middle, I didn't have another 1000uf,50v for the middle one. (sometimes you gotta use what you got to get what you want) So I powered my set up and it stays on . I hope this helps. I may go back and replace all six with 1000uf, 50v, but the space in there is limited and those are some large caps. I will wait until the set acts up again before i do that. I am satisfied with it for now. Again I hope this will help with what you've got going on with yours.10_25_2011_8_27_53_pm.jpg
Nov 26, 2007 | Labtec LCS 1040 Computer Speakers
Sony KV-32V35
Could be a problem in the shutdown circuit,in the HI Voltage detection circuit,or the flyback transformer. If your not a tech, you shouldnt be experimenting by adding parts as its going to knock you against the wall if it bites you. You should start out with a service manual and check the voiltages as now thinking it could be the power supply voltage regulator also. Please call a pro to assist you with this repair. Good Luck
Aug 02, 2006 | Sony KV-32V35 TV
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Electro Med Services...
