Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Loss of power, engine sputters
The engine almost stops when the blade is engaged
  • Mtd Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
I mowed half way through, the mower sputtered like it was out of gas. It picked back up but when I engaged the blades the power bogged down, and would only pull at a crawl, what do I need
Stop the engine, disconnect the spark plug wire(s).
Try moving the blades by hand.
Without being engaged, the blades should have a little resistance because they are still connected to each other. But shouldn't be hard to turn.
This will start you in the direction of finding out what's wrong.
A belt that's not in place, a bearing for one of the blades going bad, ect.
Sep 09, 2016 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
23 hp Kawasaki FH680v engine losses power when engaging pto!
We had issues in the UK with issues like this, they would blacken and soot up the plugs and start to run on on cylinder, there was an internally vented carb rather than the externally vented carb to cure this.
Aug 10, 2012 | kawasaki Garden
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
248 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
