Question about Dryers
Whirpool Dryer will not start. Mod # LER 8648PG0 Tried everything but replacing parts. What part do I replace first.
  • 1 more comment
  • jorge9053 May 06, 2010
    Checked fuses, now what.
    How do I verify the power?
    What setting do I put the Multimeter?
    What wires do I touch with the red and which with black?
    Please advise so that I can confirm.
    If power is present then I need to replace it, correct?
  • jorge9053 May 07, 2010
    Replaced the timer. Dryer still does not work.
    I am noticing that the dryer light stays on.
    Is this supposed to go off when door is closed?
    I can not find a switch or anything to make the light turn off.
    The door has plastic insert that a metal rod goes into, but everything is inclosed.
    Please advise.
  • 15,935 Answers
Fuses.
Check for continuity.
see the answer in your previous post -
Comment posted on May 06, 2010 CLICK HERE to see both.
One (thermal fuse) is located on the blower housing cover
#7 in THIS DIAGRAM
and one (high limit cutoff) is located at #9 in the same diagram. better seen HERE
Check for continuity on both.
Access should be from a removeable panel on the rear of the unit.
Thanks!!
Posted on May 06, 2010
  • 1 more comment
  • blueextc3221
    blueextc3221 May 06, 2010
    Verify there is power at the Timer up in the control console. If there is power - the timer i bad and requires replacement.
    CLICK HERE to see it.
    #21 in THIS DIAGRAM
    The timer controls all functionality of the unit.
  • blueextc3221
    You will find a service manual inside the control bezel.
    It will indicate the main power harness. These are the wires to probe.
    Set your multimeter to ac 100x
    You're looking for 120V supply power.
    Really - you can get the same result probing the outlet - but taking the reading at the timer rules out all wiring coming before it.
    Thanks!
  • blueextc3221
    blueextc3221 May 07, 2010
    You are correct that the door switch is not working properly if the light remains on.
    I guess I was under the assumption there was no power getting to the machine at all.
    Thats why I instructed you to probe for 120V at the timer.
    CLICK HERE to see the switch.
    Sometimes the metal tab can be bent (that little rod you referred to actuates the switch).
    #10 in THIS DIAGRAM
    The hardest part will be getting the lid popped (think hood of a car) you can use a screwdriver or putty knive to raise the hood. In each front corner there is a small tab you must release to get the lid to pop up.
    (see #20 in the diagram) Stick in the putty knife and pry upwards.
    Thanks!
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
No heat but dryer runs
First verify 220 volts of power to the dryer at the wire terminal where the cord hooks up. Look for a loose or burned connection here also. If power is OK,ohm the TCO and hi-limit thermostat on the heater canister. Ohm the heater. No ohm reading on any of these parts replace them.
Sep 29, 2009 | Dryers
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool Dryer (Model # LER 3624JQ0) that just stopped. I push the "Push & Start" Button and get absolutely nothing. Remind you, this dryer never did turn off, I had to manually stop it each time...
Check the thermal fuse on the exit chute, white plastic. You can tape the wires together to test. If the dryer runs, replace it. Part # 3392519. Thermo next to it is also bad, part # 694674. Replace it and your timer will run down. Both parts available at www.timerking.com. Hope this helps!
Jan 14, 2009 | Whirlpool LER3624JQ Electric Dryer
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool Ler 7620 Lwo
Thermal fuse for the motor is out. It's on inside on the back wall. look for the two blue wires connecting to it.
Sep 05, 2008 | Whirlpool LER8648P Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
