Question about Craftsman Garden
Sears Craftsman Model 580.752182 Pressure washer engine stops running after about 5 minutes. I can restart it - but it is difficult - then it doesn't stay running. Worked for over an 1 hour the first day I used it. Now it will not run for more than a couple of minutes.
SOURCE: won't run with air filter on
I have a fairly new pressure washer with the same problem and discovered that because it was temporarily stored on its back (rather than upright), oil seeped into the air filter housing. If you look at the air filter it may not look like it has oil on it - especially if the oil is new. Mine runs fine without the air filter, but as soon as I put it in, it does the same as yours. I came across this site since I am looking to order a new filter. Hope this helps.
Posted on Jul 13, 2008
SOURCE: pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
Posted on Nov 05, 2008
SOURCE: craftsman model 580.752020 electric pressure
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Posted on Jul 18, 2009
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
SOURCE: John Deere 3300 PSi pressure washer shutting off
I have the John Deere 3300 PSI washer. The unit has the John Deere name but was assembled by Briggs and Stratton and has a Briggs and Stratton engine. I also experienced the engine shut off after the unit ran several minutes. I also found the gas cap was not letting the gas tank vent. I loosened the cap and the engine runs fine.
I don't like leaving the gas cap loose. I am wondering if it might be practical to drill a small vent hole (1/8 inch) in the center of the cap?
Posted on Dec 07, 2009
Common carb problem, sometimes the fuel hoses need replacement. Clean carb with carb cleaner. Be sure to remember where all parts go. Get a repair kit, very cheap, clean out all ports with brass or steel bristle or something small. Put back on engine if still has problems replace carb it could be worn out
Jan 11, 2014 | Craftsman Garden
Sears pressure washer
sounds like the engine is over heating have you checked the oil?remove the top cover from the engine and look for a mouse nest
Jul 27, 2012 | Craftsman 3000 PSI 28 GPM Honda Powered...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Craftsman Electric Pressure Washer 1800 psi. Start then runs for a minute then stops.
The motor overload / thermal protection is likely the cause. Check your hose and wand / nozzle for restrictions. Is this the same hose and wand that it shipped with, or is it from another machine?
Your local Sears store can get you a user manual and diagram for our pressure washer for further troubleshooting.
Jun 27, 2010 | Vacuums
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
371 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
