Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
Darkened screen I own a Philips plasma HDTV which goes into a ''ghost'' mode for 5 to 10 minutes before the picture comes back to regular. Model #42PF9966/37. Is this a serious matter?
  • 2cairns916 May 06, 2010
    Sounds to me as though the TV would have to be opened up to do what you have suggested. Right?
  • 2cairns916 May 07, 2010
    Yes, it tells me I have to take it to a professional. Thank you.
  • 4,889 Answers
The problem you have described indicates that there are faulty electrolytic caps on the y or z sustain boards.Often in cases of problems like this, the caps do look a bit cracked or bulged near the X at the top. If any of them don't look fishy then you should get a multimeter, set it to capacitance mode and check whether any of the read values that differ from the original ratings on the surface or "OL" which means over load. I have fixed a similar problem in my shop for the same model. The caps cost me around 10$. There were 6 of them that had gone bad on the Y-sus.
Sai.
Posted on May 06, 2010
  • eagle338
    eagle338 May 06, 2010
    Yes you should take off the back cover of the tv to do this. Not recommended if you do not have prior experience to do it yourself coz the circuits hold dangerous voltages for several hours- days after the unit is unplugged from the power supply.
Picture comes on for split second
Hi.
Are you sure this is not on somthing like hide screen mode?
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Philips 42 in. Plasma TV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
May 19, 2009 | Philips 42FD9954 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Picture goes blank
What type of TV is this unit? An LCD or Plasma?
If it's an LCD, take a close look at the screen with a Flashlight and see if you can see some sort of picture (Almost like a ghost of an image). If this is the case, the backlight has failed.
If it's a plasma unit, you're probably looking at a power supply issue to the panel.
Nov 25, 2007 | Televison & Video
Philips 42PF9966 42 in. HD-Ready Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
