Question about Samsung HP-T4254 42 in. Plasma Television
Twice now Samsung has had to send repair technicians to replace the panel because of either horizontal or vertical lines. This will be the third time and warranty is over in 9 days. It is hardly ever watched. What could be causing the panel to go??? I don't want it happening again when warranty is over! Thanks
  • 1 more comment
  • connekeke May 06, 2010
    Hi, and thanks for your reply.
    What is your level of experience with Plasma TV repair?
    Is this something that is unusual?
    It has never been hit, broken or dropped. This makes no sense that we would have 3 defective panels unless something else in the TV is causing it.
    Or is it known that these panels are poorly designed/manufactured?
    I have raised hell this time and last time, but Samsung is adamant that they will not replace the TV unless the repair technician writes that it is not repairable.
    To me, getting another panel that is just going to go again soon isn't an option so I'm trying to find some bit of info that the repair tech can look into to prevent this from happening again OR some way I can influence him to say it's not repairable.
    I don't have enough info at this time.
    I found your qualifications after I replied. I hadn't noticed that section before.
    My model number is HP T4254.
    It just seems like more than coincidence that I've had 3 bad panels. Logic tells me either something else in the TV is behaving wrong and causing this, or Samsung must have a problem with this panel in general.
    Is there absolutely nothing in the TV that can cause a panel to develop either horizontal or vertical lines? Something wrong with the power that's causing pixels to blow (I'm sure this sounds stupid, but I'm not a techie!) or any other thing that can affect this?
    I have been calm but angry with them and have reiterated over and over that this this tv has serious problems and continuing to repair it when we *know* it's gonna go again is not a workable solution. I have politely but firmly dealt with this and they are just not backing down. Talked to a supervisor this time and she gave me the same song and dance. "If it's repairable - that's what we'll do."
    Grrrrr!!
    I'm sure it's hard to diagnose without seeing the unit, but you've done everything you can, I'm sure. I now have some info to talk to the repair guy with, and that's what I was looking for.
    You've gone the extra mile and I hope it pays off for me.
    Thanks.
  • 566 Answers
Hi there
To answer your question;
First make sure to have a good contact with samsung about this problem.
If you,re talking about the display panel, it usually carries a longer(not specified) warranty.
There is nothing in particular that can cause the display panel to go beside the panel itself or being hit and broken.
So make sure to keep on top of it and raise hell if you have to, until the problem is fixed.
It is not your problem if they could`nt fix it right the first time.
Hope this help Good luck
Posted on May 06, 2010
  • 2 more comments
  • Jacques Marin
    Jacques Marin May 06, 2010
    First , I actually am a working tech that has been around since the seventies and i do this primarily to help people.
    I can see that samsung is trying to cover it`s track when it comes to what i think is a series of bad panel.
    It is also my experience that they(samsung) will replace your set if you berate them enough.
    It is not a normal working situation for a tv set to have a repeated problem like yours, no matter what the cause is, or who`s fault it is.
    I will look and see if i can find anything in particular as far as your model is concerned, about bad display panel.
  • Jacques Marin
    By the way: About 75% of the tv`s we repair now are either plasma or lcd.
  • Jacques Marin
    The picture problems horizontally are usually caused by y-sustain driver boards (upper and/or lower) or the xsustain board.
    And vertically you`d suspect the control/logic board or the panel itself.
    If the power supply voltages called VS and VA are out of range it may overdrive the panel but usually causes pixels to flare(Stars like dots in the screen) as a visual sign.
    I don`t know who`s doing their service but maybe they should start to suspect some of those boards.
  • Jacques Marin
    Was my pleasure and i hope it works out o.k
    I`ll still be around if you need some help, just post your question here.
    Good luck
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
My TV is death
hi
open your tv clear dust , check capesitor,power supply ,transi sotr ,regester,
Mar 24, 2008 | Samsung SlimFit TX-S3082WH 30" TV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
Dear brother i have problem my lcd tv samsong , a vertical line is comming in right side how it will rectify ? pl suggest . thank jks
If it's a thin vertical or horizontal line which is constantly there in the same place chances are the panel is defective.Normally a panel repairs or replacement is not cost effective and you need to live with this defect or go for new monitor. Sorry !
Samir
Jun 03, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
3.5 inchs of my tv is missing
You didn't mentioned if it is vertically or horizontally 3.5 inchs black. If horizontally 3.5 inchs black you have a faulty electrolytic capacitor on the vertical section. You are now wondering why vertical section is affected,because you haven't enough vertical scanning that's why the 3.5 inchs fill only by black. Send it to repair or look for a qualified technician to replaced the electrolytic capacitor on the vertical section.
Jan 04, 2011 | Televison & Video
Horizontal lines in pictures
hi If u find that the lines are vertical that is often a result of taking pictures of very bright subjects. This is  called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician , and they will send it out to have it looked at. hope this helps!
thank u rate me!!!
Feb 12, 2009 | Olympus FE-190 Digital Camera
SAMSUNG HCM4216W has a verical line
the vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Dec 07, 2007 | Samsung HCM4216W 42" Rear Projection...
Sceptre X20G Naga III showing horizontal and vertical lines
Hi...there,
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
May 02, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Samsung HP-T4254 42 in. Plasma Television Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
