Question about Toshiba 1360 Black and White Copier
Default setting
I would like to change the exposure default to Manual, instead of Auto. How do I get into the default settings, and do this?
    Problem Solver:
  • 6 Answers
Your machine is old analague and a few years old now.It should be no problem changing.If your exposure settings are out it may be drum wear but more often or not all mirrors needing good clean.
Off top of head....M/c off..hold down 0and 8 numerics and power on...AD or AJ on display.punch in 15 and press print..... should read 00 on display... punch in01 and press green print button..press 09 and m/c ready to go if not switch off and on.
If unhappy with auto expose or manual middle expose...0+5 power on...AD or AJ on display,punch in 0+1 then print key opens exposure....pressing 1 increases light each press,,,try poss.10 times and print after to load.. and 7 decreases light to darken then print to change value. 0+9 together will get m/c to ready please try, all the best.
Posted on Mar 30, 2008
How do I fix over exposed pictures outdoors
Check and make sure you don't have the exposure compensation settings set higher than 0. There is a manual override feature that lets you apply over/under exposure compensation to every photo rather than manually setting it for each shot. Sometimes, this feature can get accidentally changed. If that's not the issue try to reset the camera back to its default settings through the menu feature.
Aug 07, 2014 | Canon EOS Rebel XSi Digital Camera
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
How do you change the default power up mode from color copy to black & white?
You will ahve to set up exactly the conditions you want for the default reset. Color option, quantity, manual or Auto exposure, etc. Then press the additional Functions key, then copy settings, press the down arrow key until Standard Settings is displayed, then depress it and then store key not initilize then OK ( YES ). This should get you in the general area of storing the settings you want.
Jun 17, 2011 | Canon imageRUNNER iR C2880 Color Copier
Our canon a450 is taking too bright pictures on daytime and when outside. do you think settings were changed because it was ok before?
You may have changed the EV (exposure value) settings, or put it into manual mode. Try to find these settings in the menus and put them back to default or auto.
Nov 08, 2010 | Canon Cameras
Hi, My Nikon D80 is now kaing over exposed
This can happen if you have ISO control set to Auto and have spot metering selected, especially if it's set to spot shadow or spot highlight. Over exposure probably means it's set to spot shadow metering.
With spot metering the camera measures exposure from just a very small point in the scene, and so slight camera movements will cause the metering spot to wander onto different exposure settings very easily. If the camera is either set to use restricted apertures or shutter speeds due to program or lens limitations then it will compensate by adjusting the ISO settings instead
Never use auto ISO, just choose what you need for the conditions rather than using the camera's best (& usually poor) guess. Alsonever use spot metering unless you know why you're using it. The default multi-pattern metering is extremely accurate for most situations.
Please check the camera settings based on what I've said, if it fixes your problem then please rate my answer. If not then please add further details of which lenses and camera settings you're using and I'll try to help you further.
Oct 31, 2009 | Cameras
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Camera over-exposes all pics, and the =/- button does not work.
hi
the Exposure button will generally be disabled in auto mode
try changing it to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Jul 04, 2009 | Samsung Digimax L60 Digital Camera
Problem on outdoor daylight picture taking
hi
try the Exposure button [+/-] will generally be disabled in auto mode
try changing mode to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
cheers
Jul 03, 2009 | Samsung Digimax L60 Digital Camera
Services default values for Vista
we have all done that, go into you bios and there you will see install default settings, they will tell you the key like F5 or F9 then save and exit. that will install your default settings.
If you only have a problem or two tell us what the are the type and model of your computer and the operating system you employ. Most of the time it is only reinstall a driver or two...
good luck, please leave rating. thank you
May 10, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Dark Images
Even in automatic mode, camera still lets you pick what ISO to use. If ISO-Auto is OFF in camera menus, this can give some dark images. Press and hold ISO button and rotate command dial to give a higher ISO, or turn ISO-Auto on in camera menu with crayon icon. Also note that the camera saves exposure compensation setting for each mode,
May 09, 2008 | Nikon D40x Digital Camera
Toshiba 1360 Black and White Copier Logo
230 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
