Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I don't know how to tighten my chain?
How do i adjust the chain on my mini quad to tighten it? 50cc
2 Suggested Answers
SOURCE: Help my sons mini pocket quad is making a ringing noise and I don't know what it is. Please Help
open the clutch case there will be a bolt came loose. the clutch is behind the chain drive bolts can come loose from vibration buy lock tight for bolts from halfords do not run untill you have fixed this will rip the clutch apart
Posted on Apr 01, 2012
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Jan 05, 2016 | Factory Motorcycles
Aeon mini kolt 50cc quad will rev a little then cuts out no power
Likely a lean condition. Clean or rebuild the carb then adjust.
Jul 24, 2014 | Motorcycles
My chain is loose
LOL.....Don't panic...
There are 2 nutz on the chain/bar side of the saw.
You must loosen first, then locate the adjustment screw (reg flat screwdriver) on the end of the bar and next to the 2 nutz you loosen at the bar/chain.
Best to set saw flat and support the end of the bar/chain, tighten chain to a point where you pull on it and it can be pulled about 1/4 inch from bar with medium strength, "snug" I like to call it.
re-tighten your nutz after adjustment.
NOTE: I have found that when you support the end of the bar it raises it a bit, after you tighten your bar the tension increases depending on model of saw. Only takes a few minutes to play around adjusting and you will get it.
Nov 27, 2013 | Garden
Adjusting a quad bike chain
The method is exactly the same as that used on motorcycles. Most quads are just 2 wheelers with a chain driven rear axle in place of a single rear wheel. There will be a nut on the axle you need to loosen, when you have done this you need to use the chain adjusters to pull the axle back to take up the chain slack. make sure the axle is at right angles to the swingarm and then tighten the axle nut to the suggested torque setting. Job done.
Feb 18, 2013 | Motorcycles
Mar 31, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Chain torque settings
I don' t have a torque wrench either, and I adjust my chain on the road, with a big adjustable, just tighten it up and go. Ducati S4, Hope this helps.
Apr 14, 2010 | 1987 kawasaki GPZ 500 S - GPX 500 R
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Got a kazuma 50cc quad have problem starting it when i finally get it going it wont take any throttle without cutting out.
i have i 50cc ATV quad and we have done every think to it and it still won't start but the fuel isn't going to the spark plug any one know what to do. ?
Jan 09, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
333 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
