Question about Toshiba TLP 670 Multimedia Projector
There's no red. green and blue work fine. Have tried adjusting colour ratio in menu. Red is black there too. There has sometimes been a single red dot projected, no bigger than that of a laser pointer. Obviously changing bulb makes no difference. A common problem? Is there a DIY solution (i.e. replace part) or is an expert needed, and how much might that cost? thanks alot in advance mike
  • zaine khan May 11, 2010
    try replacing the colour wheel,or the vga/dvi/video cable.
  • 144 Answers
Vga cord
Posted on May 08, 2010
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
How do you adjust color, color seems too green?
There should be colour settings under the "picture" tab in the menu. In the colour settings you can change the level of green, blue and red (the 3 that make white) Here you can scale the green back to make it closer to equal with blue and red
Jul 06, 2009 | Hisense TL1700 17 in. LCD Television
Hp psc 1210 all in one colour problem
The cartridge may be defective. I had that happen so I returned for another and it worked fine
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
—OR—
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
—OR—
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Sony model # kp53v90 rear projection tv
HI THERE,I HAVE 3 PICS. 1 IN BLUE,1 IN GREEN, 1 IN RED,I
USED THE FOUCUS FUNCTION IN THE MENU, BUT THAT DID NOT FIX THE PROBLEM.ANY SUGGESTION. THNX ALL.
Mar 15, 2008 | Sony KP-53V90 53" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Toshiba TLP 670 Multimedia Projector Logo
152 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
