Question about Craftsman Garden
My craftman 550 Briggs & Stratton mower just turned 3 years old. The problem is when mowing the engine just stops. After putting more fuel into the almost full tank, priming the engine the mower will start, but will after a bit smell like something burning and quick again. I have checked the oil & put fuel stabilizer into the tank. The air filter appears to be fine. Not sure of the problem???
  • Clyde Ottaway Oct 13, 2017
    SOMETHING IS IN A BIND CHECK SPINDELS AND ALL PULLEY BEARINGS
Use Briggs & Stratton ethanol free gas it is already mix and ready to use or any ethanol free gas that's ready to use.
Posted on Oct 14, 2017
SOURCE: Husqvarna LGT2654 with Briggs & Stratton Intek Engine won't start
If the fuel line is dry after the fuel pump its usally the diaphram thats stuffed does it have a fuel tap in place? is it off? also i know with nem mowers just been come over from freight the fuel filter is full of oil for the first start up as the valves need lubrication first startup... take the fuel line off from the carb just have it hanging down for a start, then crank the mower over, you should then have fuel coming out of fuel line by then... see if that helps jay QLD AUS
Posted on Feb 24, 2009
  • 97 Answers
SOURCE: Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Posted on Mar 19, 2009
panilling9
  • 284 Answers
SOURCE: gap setting for champion RJ19LM spark plug 3.5
plug gap setting is .030
Posted on Jun 10, 2009
  • 81 Answers
SOURCE: Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
Posted on Jun 17, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
After finishing mowing my lawn the other day, my mower leaked (dripped) gas from beneath the bottom of the carberator. What should I do to get the leaked stopped?
Ok, first thing you need to do is check your oil. Make sure no gas has gotten into the oil. if it has then be sure to drain it.
carberators today are really having problems with very tiny dirt particles making them malfunction. after cleaning my carb 3 times in one year and having to change the oil each time, i decided to get a 6 dollar fuel shut off valve. i cut the fuel line and installed the valve. when done mowing i turn the valve off and have not had a problem since. in fact i have put a valve on all my small engine equipment.
Apr 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have an 18.5 Intek Craftman Tractor. The battery
pull the plug out and crank it over....if it's been sitting, there's liquid fuel in the cylinder...can't compress liquid...drain the carb too...use fresh fuel...
Apr 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Garden Logo
354 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
