Question about Whirlpool Dryers
Dryer will not start. Checked outlet and fuses power to dryer but not start up. Opened up back panel no loose wires. Cleaned up any loose lint. Tried turing all knobs but dryer will not start.
  • 1 more comment
  • jorge9053 May 06, 2010
    The make Model # Whirpool LER 8648PG0.
    I can use a multimeter.
    I do not see any fuses.
    I see no fuses.
    Whirpool
    Mod # LER 8648PG0
    There seems to be continuity between fuses. Checked both fuses.
    What are my next steps.
  • 15,935 Answers
Did you just finish a big load?
There are some fuses on the dryer itself.
Are you handy with a multimeter?
What is the make/model # of the unit please?
Thanks!
Posted on May 06, 2010
  • blueextc3221
    blueextc3221 May 06, 2010
    CLICK HERE to see both.
    One (thermal fuse) is located on the blower housing cover
    #7 in THIS DIAGRAM
    and one (high limit cutoff) is located at #9 in the same diagram. better seen HERE
    Check for continuity on both.
    Access should be from a removeable panel on the rear of the unit.
    Thanks!!
Kenmore elite dryer. model 110.6708 or 09. check lint screen light is on. I have cleaned inlet/outlet/screen/front and back. unit will start but will not heat. if in the normal setting the f40 code wi
The F40 error code indicates a communication failure between the main machine control board and the motor control board for the blower motor on the dryer.
This can be caused by a loose wiring connection or a blown fuse.
Nov 22, 2012 | Dryers
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
I dried 2 loads of laundry this morning and when I went to dry the 3rd it just wouldnt start. Its 2 yrs old. Everything is plugged in and I have checked the fuse box. What else could it be?
Hello there:
If You have inspected the dryer and cleaned out the lint Screan and all other areas you can unplugit for 30 min and then plug it back in but if this does not help please go thru this troubleshooting list that i have made up for you
If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 18, 2010 | Dryers
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Dryer does not start
Check the fuse on the blower housing.
To get to the heating element on most of these dryers you remove the back dust cover: whirlpool%20dryer.jpg 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
Sep 13, 2009 | Dryers
Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Mar 25, 2009 | Dryers
Gas dryer won't run when pushing start. Motor not comming on.
There is a small resetable fuse athe back under the top cover being held by a plate that has a screw holding it in place. To test just connect the wires together. I see this all the time on those modeles.
Mar 15, 2009 | Amana NDG7800AW Gas Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
18 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
