Question about Panasonic PAN TOUGHBOOK 29 C9/1.4 80GB 512MB (CF29HAQGZBM) PC Notebook
I installed a new 160Gig Hardrive on my Toughbook CF29 and when I boot the system it says "No operating system found" It had winxp on the old HDD
    President:
  • 2,666 Answers
The HDD must be installed with the OS it does not come preinstalled.
Your new HDD is blank.
Posted on May 06, 2010
Testimonial: "Thank you quick and helpful"
Cf-29 does not work anymore with my linksys. Ipad works with the linksys though.
On ALL older Panasonic Toughbooks the original
WIFI drivers were the original drivers which shipped
with the operating system.
These drivers usually have a date of 2003 or 2004.
There are NEWER WIFI drivers that work with the
latest routers (G or N). The new drivers have dates
of 2006 or 2007 for Windows XP and 2008 or 2009
or even later for Windows 7.
The CF29 MK1 used a WIFI "B" Adapter which is limited.
The MK2 used a WIFI "G" Adapter which will be easier
to update.
Panasonic CF29 usually used Intel Brand WIFI adapters
so drivers could usually be found at the link:
https://downloadcenter.intel.com/product/3821/Intel-PRO-Wireless-2200BG-Network-Connection
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 13, 2014 | Panasonic Toughbook CF-29 Notebook
External display video monitor
On Page 10 of the Operating Instruction Manual
for the Panasonic Toughbook CF29, it shows
the "External Display Port" or VGA Connector
located on the back side with the cover closed.
This port is located approximately in the center
of the back side, just to the right of the
port replicator port and may be colored "BLUE".
The manual can be found here:
ftp://ftp.panasonic.com/computer/om/cf-29htlgzbm_en_om.pdf
Good Luck!
Regards,
Feb 02, 2014 | Panasonic Toughbook CF-29 Notebook
Cf-29 no operating system
You will require the internal Panasonic Toughbook CF29 optical drive (DVD). The cost of such a drive (used) in should be $50 or less.
You will also require a Windows 7 DVD.
You may be able to download an ISO file and burn your own.
Try this Microsoft Website:
https://www.microsoft.com/en-ca/software-download/windows7
You must use the 32-bit version, NOT the 64-bit version.
Please remember to set the DVD as the first boot device in the BIOS of the CF29.
That is it. Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jan 27, 2014 | Panasonic Toughbook 34 PC Notebook
Ethernet driver
All Panasonic Toughbook Drivers can be
found at the following Website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Click on your particular model (ie. CF29),
choose the version (MK1, etc.), choose the
operating system (ie. Windows XP),
then choose the driver (ie. LAN Driver) and
click on "Download Now".
Voila! That is how you find the Ethernet driver
for the Panasonic Toughbook CF29.
Good Luck!
Regards,
Panasonic Canada Toughbook Dealer since 1989
Sep 19, 2013 | Panasonic Toughbook CF-29 Notebook
Help how to remove old boot of winxp prof, in win7prof, please i was using windows xp ,then the other day i was installing xp on top of the other because the computer was affected, then the system drive...
Open "RUN" then type "msconfig"
Click on "Boot", choose which one of OS you want to delete and then click "Delete".
After that, click Ok to apply settings
Dec 07, 2012 | Computers & Internet
My cf29 Panasonic toughbook have no boot file name/ pxe-e53
This error is a network boot error.
The error message indicates that the client received at least one valid DHCP/BOOTP offer, but does not have a boot filename to download.
A fix to this problem is found on this WEB site.
http://www.bootix.com/support/problems_solutions/pxe_e53_no_boot_filename_received.html
May 18, 2012 | Panasonic Toughbook CF-29 Notebook
Hard drive is full
Aquire disk imaging program such as norton ghost. Install 2nd, larger HDD into existing computer. Boot computer using ghost boot disk. "Image" existing HDD to newer, larger HDD.
Remove existing HDD. Set 'new' HDD to proper position (Master, etc).
Boot computer.
Joy.
Feb 19, 2009 | Microsoft Windows XP Professional
Disk boot failure
Technically you can copy all the data from one to another hdd but not the operating system
You have to install your operating system (windows, linux or MAC) on your new 500gig hdd and then copy your data from 60gig hdd.
Regards
Jan 22, 2009 | Avanquest DISK COPY & CLEAN (WIN...
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Administrator
One possible solution would be to obtain a windows installation disk for the operating system you're using...which will allow you to format the hard drive and do a new windows installation.
Jan 12, 2008 | Panasonic Toughbook CF-27 Notebook
Panasonic PAN TOUGHBOOK 29 C9/1.4 80GB 512MB (CF29HAQGZBM) PC Notebook Logo
194 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
