Question about Apple iPhone Smartphone
Cannot get my ITouch to connect to my wireless router
Above
  • Anonymous Mar 29, 2008
    just got an iTouch i need wifi password to connect to wifi what do i do?
Sounds likes the internet you are trying to connect to is locked meaning to access it you need its password. Hope that helped.
Posted on Jul 07, 2008
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Dec 26, 2012 | Toshiba WRC 1000 Wireless...
My wifi network is on but my itouch isnt seeing it why is that
check your itouch to see if you see the router.
Follow these instruction to set up wifi device.
.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the ITouch up in the router by WEP/WPA KEY or MAC address.
6.Note router name you are connecting to.
This is for all routers to set up wirelessly.
Aug 16, 2010 | NetGear DG834G Router
Computer will not connect
I think I have experienced the same problem. ITouch does not have the same wireless security options as the wireless router does. What you need to do is to find what wireless security options the ITouch has and then set the wireless security on the router to an option the ITouch has. The reason it does not save is that it is detecting that there is a problem, it's stupid and thinks it is just the password that is the problem.
Hope that helps. You might get a better answer if you are able to provide better detail as in what wireless security you are using on both devices
Regards
Raph
May 27, 2010 | Linksys Wireless-N WRT150N Router
My mom gve me a Wireless-G access point Linksys
I suggest resetting the router to the factory defaults by holding in the reset button located on the back of the router for 30 seconds.
The router will reset to the ip address of 192.168.1.1 and you can log into it using either a blank username and the password admin or using the username admin and the password admin.
Please let us know if the above was helpful and if there is anything more we can do to resolve your issue. Thank you.
Sep 16, 2009 | Linksys Wireless-G Broadband Router
How can i connect my ipod touch to the netgear maxrange router wpn824v2
Follow the steps below to configure settings:
1. Open a browser on a computer connected to the router.
2. Access the router using http://www.routerlogin.com or http://192.168.1.1
3. Username is admin and password is password
4. Click on Wireless settings in the left hand side menu.
5. Under security option select WEP and in key1 type 9876543210 click Apply.
Scan for the wireless network on the Itouch and connect to the network using the password as set above.
Rate it, if it helps.
Anand
Jul 12, 2009 | NetGear RangeMax WPN824 Router
Itouch Connection To Home Broadband
Hi, for DNS use the following information:
Primary DNS 4.2.2.2
Sec DNS 4.2.2.1
Password prompted by Itouch is the WEP password. Make sure tht you restart the itouch and then try to connect to it.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 04, 2009 | NetGear DG834G Router
Can't connect iTouch to Verizon GT704WG wireless router
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Not really a problem
You can setup the router to work with modem. When computer is online behind the router you can just connect your Itouch wirelessly to have wireless internet.
Oct 02, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear DG834GT
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Jan 05, 2008 | NetGear DG834G Router
Apple iPhone Smartphone Logo
91 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
