Question about Dometic RM2193 Compact Refrigerator With Ice Box
HOW TO START / OPERATE THE FRIDGE
I HAVE A 1998 POP UP CAMPER WITH A DOMETIC 2193 FRIDGE BUT NO INSTRUCTION ON HOW TO START OR OPERATE
  • Dometic Master
  • 6,674 Answers
Here's a link to download PDF file for your fridge.
http://bryantrv.com/docs2/docs/rm2193.pdf
Posted on May 09, 2010
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
Our Dometic refridgerator in our 1992 camper
I would start there before replacing any parts. The circuit boards require 12volts to operate the refrigerator. If you have a good 12 volts and the LP tanks are full and the flame lights but the unit does not cool then you probably have a bad cooling unit. But start with the obvious issues first.
Sep 03, 2013 | Dometic RM2620 Refrigerator
I have a 2009 pop-up camper with a Dometric 2193. The previous owner stated they never used the unit. They only had the camper for 5 months. I cannot get the unit to cool with gas or electricity. I The...
One of the first things I advise a new owner of any RV is to have the propane system checked by a certified RV technician. I have seen brand new units from factory with propane lines left unattached to appliances, as well as past owners of used units who have decided to try a few things of their own that were extremely dangerous. This unit apparently has sat for approx. 2 yrs, and spiders etc can build nests, bees can build nests that will block ventilation etc, which all can create a situation for a fire or worse. PLEASE, spend the $60, let them clean and inspect the system to give you piece of mind and know that it is safe for your family and friends as well as you. My guess is that it is not a serious problem, and good chance still covered on 3 yr. warranty.
Mar 10, 2011 | Dometic RM2193 Compact Refrigerator With...
Have dometic three way fridge in pop up truck camper that is cooling but not cold enough stays at about 50 degrees answers???
Find thermistor/thermostat that is usually attached by plastic holder at back on one of the fins in fridge compartment. Pull it off, and move it over to left 2 fins, then give 24-48 hrs and see if any change.
Jun 16, 2010 | Dometic RM2652 Refrigerator
Not working on propane
Shut it off, (propane) and used compressed air to try and blow up that stack and clean out any rust that may be in there, as well as check for baffle hooked at top of stack, and hangs down inside the tube.
Jun 01, 2010 | Dometic RM2193 Compact Refrigerator With...
Dometic RM 2193 freezes everything. How do I reduce the flame size. Also the flame goes out whule on the highway. Any ideas? cheers gerry
ok if your flme is going out while driving u may need to make sure everything is closed where the burner is at and if ur fridge is freezing everything turn the temp down
Jan 29, 2010 | Dometic RM2652 Refrigerator
The fridge will not turn on. Should I be turning on the 100 switch, even if the camper is plugged in, and the lights are working?
Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
Sep 01, 2009 | Dometic WA3210 Compact Refrigerator
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
545 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
