Question about Swintec 7040 Typewriter
When typing, the letter keys are not matching up to what is printing out.
  • Swintec Master
  • 3,594 Answers
The Pitch selector switch gets dirty Slide it up and down a few times & leave it at 10 or 12.
DickyO
Posted on May 27, 2010
When typing the keys pressed don't match up to the
Check the pitch switch on the L. side of the keyboard it shoul be in 10 or 12, if it is slide it up and down a few times they do get dirty.
Setting margins: When using the mar, rel, key don't hold it down just press and release.
DickyO
Mar 21, 2010 | Nakajima Office Equipment & Supplies
Keys don't match letters
On the L. side of the keyboard is the pitch selector switch it may be in PS proportional space it should be in 10. 12 or 15 also dlide it up & down a few times they do get dirty.
DickyO
Jan 05, 2010 | Nakajima AE-710 Typewriter
Nakajima AE830 is not typing the correct letter
Although there was not visible problem or damage - we found that replacing the print wheel resolved our problem.
Jul 22, 2009 | Nakajima AE-830 Typewriter
When typing the letter n 2 letters print nm
Sounds like your keys are sticking together. Pop the affected keys off with a flat tip screw driver and remove any debris. If there is something sticky, remove with Q-Tip soaked in rubbing alcohol. Then replace keys.
Jul 19, 2009 | Sony Computers & Internet
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
DL PRT how to release this function??
On the rt. side of the keyboard is a key that says print mode.
press that key the dl print should go off on the display and you should be in business.
DockyO
Feb 23, 2009 | IBM 3500 Typewriter
When I type it is printing different letters than I am typing.
On most models there is a pitch switch 10.12.15.PS
you need to match the switch to what print wheel is in the typewriter. most common wheels are 10 or 12
move the switch to that area.
if that is not the problem take out the ribbon, corr. tape & print wheel. tuen on the typ. let it home, put the print wheel & ribbon ( Not the corr. tape) turn on let it home tray typing. if works O.K. put in the corr. tape .
Then you are good to go.
Jan 29, 2009 | Office Equipment & Supplies
Keys don't match what types. Letters type other letters.
Check the connectors from thr PC board to the keyboard, if they are OK tren try this hold the code key press and release the "L" key type 001 release thecode key. If this works you need a keyboard to repair it'
DickyO
Jan 24, 2009 | IBM 3500 Typewriter
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Jan 14, 2009 | Nakajima AE-710 Typewriter
Swintec 7040 Typewriter Logo
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
