Question about Samsung WF328AA Front Load Washer
Kenmore Elite QuietPAK2 HE3 noise problem and rubber seal issue
I have a Kenmore Elite QuietPAK2 HE3 front loading washer(model#110.45862403)for several years.The washer seemed to work well for the first year.After that,we are experiencing loud spinning noise and the whole house shakes. I tried to wash less clothes rather than a full-load as we were told to save money and energy.It seems to work better (less noise)then but my feeling is why own a washer which you can't even do a full-load. Recently, I noticed my clothes and towels smell bad (like mildew),and water is leaking through the glass door because the rubber seal seems out of shape/place and sometimes clothes would get stuck in it. From all these issues,I'm so afraid to use the washer now, fear that my house will be flooded with water and the clothes might get rip. I wish I can have it fix but didn't have the warranty to repair it. I've though about purchasing another washer, like a top-loading washer rather than a front loading one. If someone has any information on how to repair my washer. Please reply.Thanks
    President:
  • Samsung Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For the shaky washer:
Adjust your washer's front legs and lock the nut, it has another nut to do this. After you hav locked the legs, try to rock the washer with your hands, it should not rock. Another thing to check will be inside your washer, after taking the power off the wall socket. Check to see if some springs or the shocks (dampers) have come loose. This normally happens when the load is not even, that is when you hav a big sheet in one part of the washer tub. Spread out the clothes evenly before you commence the wash. To see if washer is firm: hold the front portion of the washer, the 2 corners and try to shake it, if it does not move, it is fine.
Pump: If you are handy at all this is simplicity itself. Check the pump - slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. (make note where wires go) Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble.
Washing a full load is better than 2 or 3 small loads, saves electricity, etc. But if there is a loud spin noise, means that your bearings are wearing out. Is your belt too tight?
For the smelly washer:
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
http://ezinearticles.com/?Cleaning-Your-Washing-Machine&id=109993
For most front-loaders: rubber boot, seal
Remove the top, screws behind the top lid. Slide an inch away from you & lift up. Remove old seal. Lubricate the slot which fits over the tub with washing-up fluid, if you find resistance. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps)
Try these sites for spares
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl rate me ‘very helpful’ for the free help. Thnks!
Posted on Jun 20, 2010
  • viperjuice Jan 20, 2011
    I'm having the same problem with my washer as far as the shaking and the mildew. Still trying to figure out the shaking. As far as the Mildew I red in the instruction manual to leave the door just slightly cracked open when not used to let inside dry out. Run an empty load with just bleach to try to reset the springs and will also get rid of mildew and them leave doors cracked open. Don't have the mildew problem anymore.
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite washing mahcine HE3 quietpak2 Model#110.45862404 - The selecting cycle wash button does not follow command. It is only delicte and handwash cycle wash botton is working.
Sounds like a problem in the button panel, but could be firmware is in a knot, which is an easy fix: Try unplugging machine and plug back in 5 minutes later. Then see if it works.
Jun 19, 2015 | Kenmore HE2 Plus Front Load Washer
How can I get an operators manual for a kenmore elite quietpak2 HE3 washer?
See the following Sears site for manuals:
http://www.managemylife.com/mmh/owner_manuals/search/product_type.Residential%20Washers?query=kenmore+elite+quietpak2+HE3
You'll have to determine the actual model number and then you can download a PDF version of the manuals.
Nov 18, 2010 | Kenmore Washing Machines
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Samsung WF328AA Front Load Washer Logo
322 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
