Question about Belkin (F5D7230-4) Router (587009)
Belkin may belkin work fine but sometime I can not connect to the internet and a tried to restart belkin with the I.P adress but it is stil the same
    President:
  • 524 Answers
  1. Click on START,
  2. Right Click on MY COMPUTER
  3. Select PROPERTIES
  4. Click on th HARDWARE Tab
  5. Click on the DEVICE MANAGER Button
  6. Scroll down to NETWORK ADAPTERS and find your wireless card.
  7. Right click on it and select PROPERTIES
  8. In the DEVICE STATUS what is written in there <REPLY 1>. If it says THIS DEVICE IS WORRKING CORRECTLY - - Then drivers are ok here. If it says something else POst Back with what it says. and then Update the drivers.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
Why Can't I connect my belkin wireless range extender with apple time capsule?
Its very simple just follow these steps -
  • Restart Your Modem First than Restart your Router And Extender
  • Please Your Extender With in 30-35 Yards Of Your Main Wireless Router .
  • Make Sure All Lights Are Blinking On Router And You Have Internet to your Router
  • Try Connecting The Extender Again See if That Works
For more Details kindly visit
Belkin Range Extender Won Connect to Internet Belkin Range
Jul 05, 2012 | Belkin Computers & Internet
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
Belkin router F5D8638-4 laptop connects but no internet access
Make sure you entered the same key exactly the same way in both the router and the computer. Also, make sure you have selected a Security protocol that is supported by the computer. Some versions of Windows do not support WPA. XP supports it but really doesn't like to auto detect it. If it's a HP laptop make sure you are using a communications channel other than 6. Some routers give you an option to select the channel HP computers don't like working with channel 6.
Jul 28, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
BELKIN F5D8236-4 V2:Router keeps loosing wireless connection
hi..
check the range in which you are using the laptop.please use the laptop within 6 meters if you go more than that it is difficult to recieve the signal.
if stil the problem presists then try connecting with wireless internet with some other laptop if the problem presists then it the modem problem service or replace it. if it works fine then the problem is on laptop.check with the dealer.
if you are satisfied with my answer please vote
Jul 13, 2010 | Belkin F5D8236-4 Router
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
When i try to use the internet on my stuff it does not work
If all of your stuff has been working fine until now, try unplugging the router for a few mintues and then plugging it back in. Then restart each of your devices. If you've already done all of this, then it is possible your router has died.
Feb 06, 2010 | Belkin Wireless Cable/DSL Gateway Router
F5D7230-4 wired laptop wont connect
It is not a router configuration problem its a laptop problem in the configuration. Do you have the network card installed if so try a reinstall. if not go to your network wizard and set it back up .
Oct 07, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin F6d3230-4 No internet
Since this has happened to you in the past, my first suggestion would be to purchase another router.. I would recommend moving to a Linksys Brand (made by Cisco), since I believe it is a much better grade consumer router...
But, you might try resetting it back to its original configuration by pressing the 'reset' button for more than 30 seconds, then plugging it back into the LAN..
Another thing you could try is to install updated Firmware for the router... Firmware is usually available from the manufacture's site...
That being said, I will say that I have had issues with Belkin's in the past, and no longer suggest them to my customers.
Dec 04, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Belkin (F5D7230-4) Router (587009) Logo
112 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
