Question about Dewalt 18 Volt Compact Drill Kit
BATTERY SHORTS WHEN YOU INSERT BATTERY
BATTERY SHORTS WHEN YOU PUSH TRIGGER
    Problem Solver:
  • 13 Answers
If it is new Nano Li-ion technology- try to fully charge battery, they work FULL power until they discharge, so they die instantly, NOT like Nickel batteries go slower till they die, so maybe that is only your first impression that it shorts...
Posted on Jun 01, 2010
How to enter the scanner SYMBOL MC9090 boot loader in the IPL (Initial Program loader). What you need to press or do to start downloading bootloader IPL.
you run IPL with a cold boot
  1. Press the primary battery release on the mobile computer to partially eject the battery from the mobile computer.
  2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and the Power button.
  3. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is fully inserted.
  4. The mobile computer initializes.
May 20, 2014 | Symbol MC9090 Barcode Scanner
All start menu items missing. Previous employee
Please try performing a cold boot that restores formats, preferences and other settings to default settings:
  2. While the battery is partially released, simultaneously press and release the handle trigger and the power botton.
  3. Push the battery to fully re-insert it in the mobile computer, one audible click should be heard when the battery is fully inserted.
  5. Calibrate the screen.
Mar 17, 2011 | Zebra Symbol Technologies MC909X-G Series...
How do you restart nintendogs
No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
Feb 12, 2010 | Nintendo DS Lite
When pushing trigger it starts then stops quickly
if its on an extension cord then definitely. You need to run those on 220-240 or use s super short cord. Make sure you have good airflow too.
Feb 02, 2018 | Miller Spectrum 375 Cutmate Plasma Cutter...
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Hitachi DS18DL drill quits under load
sounds like your battery is either shorted out or out of charge
Jun 22, 2009 | Hitachi 18V Lithium Ion Cordless...
I cannot put the cable in the power jet handle it will not go in
Please call us at www.rjbowers.com to have someone help with the problem. It sounds like the hose will not attach to the trigger gun. Have trigger gun near when you call 1-800-383-6584 to help solve your problem.
May 11, 2009 | Karcher K2.26 Electric Power Washer
I need to change the cord on my 9392 Milwaukee Drill. The trigger does not have any screws and, I cannot not see how to change the cord out. The ground wire is attached to a screw connector.
On the trigger switch, if you look really closely you will see that there are clips inside where the wires go in. If you use a jewelers flat screwdriver or other narrow flat instrument, you can push the clip back enough to release the wire.
If the replacement cord doesn't have clips on the ends of the wires, make sure that you tin (apply solder) to the ends of the new wires before inserting them into the trigger. This is needed to keep the individual strands from being pushed everywhere and causing a short, and stiffens the end, making it easier to insert.
If you need further assistance, let me know.
If this was helpful for you, please rate the solution.
Apr 20, 2009 | Milwaukee Tool Drills
PPT2846 Dies Whenever Scan Trigger is Pushed
sounds like you have a faulty laser moule, which overtaxes / shorts accross the battery, I am unsure whether this is user servicable, and may require a prefessional repair to replace the laser pack.
May 05, 2008 | Symbol PPT2846 Portable Terminal
Dewalt 18 Volt Compact Drill Kit Logo
100 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
