Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
GE smartwater filter (model GXRLQR) stopped working...help!
I have had a GE smartwater filter (model GXRLQR) hooked up from my water line to my refrigerator for 7 years; and when I changed the filter recently, the water is flowing extremely slowly. This has never happened before in the many times I have changed the filter in the past. Anything you can suggest to help would be greatly appreciated.
Thanks!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
Posted on Sep 12, 2010
  • 4 more comments
  • Camelia Roberson Oct 06, 2011
    Thanks for the tip. I tried it and works only if I keep the filter tight on the valve piece. Otherwise the filter is unscrew itself enough for the water flow to stop.
  • Ronnie Sandy Downing May 26, 2012
    Thank you musicman! Worked the 1st time with a thin rubber (old) washer that we took off of our decrepit sprayer (and washed before we installed it ;))
    GE, you'd better get it together on this product defect!
  • Scott Linge Jul 23, 2012
    It does work. Ronnie is right, use a thin old washer or sand down a new one. I used the cheap yellow washers because they are smaller than the professsional grade red rubber type.
  • cuuld
    cuuld Jan 20, 2013
    Just wanted to mention that this trick didn't work for me, or my water filter line itself has low water flow. Don't want to bother verifying that right now, having to dismantle water line to test that, I think, or can you run the filter system w/o filter? Anyhow, for me adding the water made no difference, and if I instead tried 2 washers stacked together or an O-ring gasket washer instead of regular hose washer, it appears to not seat/connect properly (too thick now) and thus I get no water at all. That or I haven't tried enough times to ge it to seat properly.
  • cuuld
    cuuld Jan 20, 2013
    Just wanted to mention that this trick didn't work for me, or my water filter line itself has low water flow. Don't want to bother verifying that right now, having to dismantle water line to test that, I think, or can you run the filter system w/o filter? Anyhow, for me adding the water made no difference, and if I instead tried 2 washers stacked together or an O-ring gasket washer instead of regular hose washer, it appears to not seat/connect properly (too thick now) and thus I get no water at all. That or I haven't tried enough times to get it to seat properly.
  • RonnieSandy Downing
    RonnieSandy Downing Feb 24, 2018
    6 years later and the same thing happened with an off-brand replacement filter when we didn't use a washer. Just applied the washer trick and the water is flowing again. Hallelujah!
    New Friend:
I have a smartwater filter from a ge gshf6hgdbcbb refrigerator that stopped working after a few months of using it. At first, the water came out slowly. A technician came and looked at it and said the filter had to be replaced. Replacing it didn't fix the problem. The water was still coming out slowly. Eventually, the water just stopped coming out. I thought the problem might be with the hose connection, but that appears to be fine. I suspect that the problem might be that the connection of the filter in the freezer door may be frozen. Any ideas on how I could fix this problem?
Please Help!
Tony
Posted on Aug 09, 2014
Confirmed! The washer mod works! I used a standard black garden hose washer. It was about 1/8" thick.
Posted on Sep 24, 2012
    New Friend:
Thank you! The washer trick worked for me as well, although not as smoothly.
I got no water flow at first, even after a number of attempts to get the washer to sit properly as musicman77 suggested. Turned out the spring-load valve was shut too tightly.
I turned water supply off to relieve the pressure, and reached in with my finger to make sure the valve can be easily push (up) open before I inserted the washer and screwed in the filter.
Posted on Aug 07, 2014
Great suggestion..saved me time and money, thank you.
Posted on Oct 08, 2011
Gxrlqr filter leaks
MAKE SURE THAT WHEN YOU REPLACE THE FILTER IT IS IN THE SAME ORDER AS THE ONE YOU REMOVED OR THAT IT IS THE SAME MODEL TYPE REPLACEMENT , I WOULD TRY TO TURN IT AROUND FIRST , A THIN WRAP OF "WHITE PLUMBERS TAPE" , AROUND THE SCREW TOP INNER SEAL MAY CORRECT THE LEAK , ABOUT THE FILTER , WELL , IT MAY JUST BE SIMPLY IN THE REVERSE ORDER , TRY TO FILP THAT OVER , AND WHEN YOU RESEAL THE CAP ON THE FILTER MAKE SURE THAT THE SEAL IS ON PROPERLY , APPLY PLUMBERS TAPE ONCE AROUND , AND *"BEFORE YOU TIGHTEN IT" , GENTLY , REVERSE THE CAP BACKWARDS , SLOWLY , UNTIL YOU FEEL IT "SEAT " PROPERLY , "THEN" YOU MAY TRY TO RE-TIGHTEN IT . THIS SHOULD REMEDY YOUR LEAK , IF IT CONTINUES MAKE SURE THEN THAT YOU HAVE THE CORRECT REPLACEMENT FILTER MODEL FOR YOUR PARTICULAR ITEM . HOPE THIS HELPS YOU . NOW GO FIX IT ! GOOD LUCK .
Aug 19, 2012 | General Electric GE SmartWater Household...
The filtering system GXWHO4F came with no directions.
http://waterheatertimer.org/pdf/GE-smartwater-GXWH.pdf
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on filter or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 27, 2011 | General Electric GE SmartWater Household...
I have a six GE Model GXWHO4F smart water filters.They are all wrapped and in the garage however the last freeze was very cold and all six broke the bottoms out. I would like to purchase only the holders...
Optional accessories are available (Visa,
MasterCard or Discover cards accepted) by
visiting our Website at ge.com or from Parts and
Accessories 800.626.2002 (U.S.) or 800.663.6060
(Canada).
Maybe they got them, maybe they don't.
Mar 14, 2011 | General Electric GE SmartWater Household...
I have a ge smartwater filter system #GXWHO4F. My problem is that since system was installed the water pressure and the water volume drops alot when more than one faucet is turned on.The filter system...
Filters always reduce pressure.
You can add a pressure tank between filter and tankless.
Tankless are sometimes like bowling on a ship.
Add a comment saying how you fixed problem.
Fix most tankless problems yourself, same day, all brands for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Mar 03, 2011 | General Electric GE SmartWater Household...
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it...
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
Nov 29, 2010 | General Electric GE SmartWater Household...
I have a smartwater filter (model GXRLQ) under my sink and when I changed it, it began making noise like air was in the line. After the noise stopped, the water is barely flowing. Any suggestions?
If you were simply changing the filter, then I would pull the new cartridge back off and inspect the o-rings. It's possible that one got bunched on the install and is blocking the inlet/outlet of the water. Other wise if you had to turn off the water any where to change the filter, check the valve that the water runs through to see if it is turned on all the way.
Aug 18, 2010 | General Electric GE SmartWater Household...
How do you change the GE smart water filters?
This page might help with changing it, as different models vary.
Feb 18, 2010 | General Electric GE SmartWater Household...
GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Mar 28, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
2,714 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
