When I try to open an ol(debugged) VB 6.0 project I get the message "Error during load." ny ideas?
  • dgvs May 13, 2010
    Thanks!!
  • 249 Answers
Hi!
If you could post the whole error message. That would be great.
It could be a couple of things. It could be a damaged vb project file or vb file or modules and so on. But most likely this is a damaged vbproject file. Thats the reason why it does not load. I think I remember having this kind of error before. You should try this. What I did before was I copied the other files like the vbs, modules, class files to another folder. Then I created another Project where I copied those files. Then all I had to do is modify the setting or the properties of the new project so that It would load my default form or mainform.
I hope this helps you out.
Posted on May 06, 2010
  • dgvs May 13, 2010
    In addition to the Message Box with "Error during load the .log file referenced is included below. Thanks for your replyLine 687: Class SHDocVwCtl.WebBrowser of control WebBrowser1 was not a loaded control class.
    Line 693: The property name ExtentX in WebBrowser1 is invalid.
    Line 694: The property name ExtentY in WebBrowser1 is invalid.
    Line 695: The property name ViewMode in WebBrowser1 is invalid.
    Line 696: The property name Offline in WebBrowser1 is invalid.
    Line 697: The property name Silent in WebBrowser1 is invalid.
    Line 698: The property name RegisterAsBrowser in WebBrowser1 is invalid.
    Line 699: The property name RegisterAsDropTarget in WebBrowser1 is invalid.
    Line 700: The property name AutoArrange in WebBrowser1 is invalid.
    Line 701: The property name NoClientEdge in WebBrowser1 is invalid.
    Line 702: The property name AlignLeft in WebBrowser1 is invalid.
    Line 703: The property name NoWebView in WebBrowser1 is invalid.
    Line 704: The property name HideFileNames in WebBrowser1 is invalid.
    Line 705: The property name SingleClick in WebBrowser1 is invalid.
    Line 706: The property name SingleSelection in WebBrowser1 is invalid.
    Line 707: The property name NoFolders in WebBrowser1 is invalid.
    Line 708: The property name Transparent in WebBrowser1 is invalid.
    Line 709: The property name ViewID in WebBrowser1 is invalid.
    Line 710: The property name Location in WebBrowser1 is invalid.
  • Jubert Ledesma
    Jubert Ledesma May 13, 2010
    I see. Your reference to the webbrowser tool may have been removed.
    You would need to load the webbrowser tool. You could right click the toolbar and add it there or you could go to project then add reference or references.
    You need to load the web browser to be able to use it.
    I hope this helps.
How can I overcome an oL error message?
If your unit has the stabilizing bars in the four corners then that is the problem,need to replace!
Dec 08, 2015 | Washing Machines
SQLCE database connection problem on MC1000
Try disposing your database object properly by making use of the using keyword.
Uunless you need your connection open. But it is not recommended.
Jun 15, 2013 | Symbol MC1000 Barcode Scanner
We are getting the oL message even when we wash a light load or even run the machine empty. The machine seems to be spinning, but cuts off with the "oL" message sometime between the rinse and...
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Feb 18, 2011 | Kenmore Oasis HE 27082 Top Load Washer
How to run vb
How to Run a Visual Basic Program on a PC By an eHow Contributor
Like C++, C Sharp and Java, Visual Basic (VB) is an object oriented programming language. Recently it was integrated to the Microsoft .NET Framework. The .NET Framework is a software infrastructure that speeds up program development. It is supported by the Microsoft Visual Studio Integrated Development Environment (IDE), Microsoft's chief programming environment, and that of SharpDevelop.
Difficulty: Easy Instructions Things You'll Need:
  • Visual Microsoft Studio and .NET Framework
  1. Launch your Microsoft Visual Studio. It is a "heavy" application so depending on how much RAM you have it may take a few minutes to load.
  2. Click the Project tab on the first screen. Notice two buttons at the bottom of the screen named "New Project" and "Open Project." Since the tutorial assumes that this is your first VB program, click the "New Project" button. If you worked on a project before, its name will appear in an area labeled "Open an Existing Project" with a hyperlink that opens the project.
  3. Select "Windows Application" in the "Visual Basic Projects" folder if you intend to run your end program on a computer running a Microsoft Windows operating system. Focus in the "Name" text box near the bottom. Change the name from the default to something more descriptive such as "MyFirstVBProgram." Leave the Location to the default value to save your project to the "My Documents" folder. Press OK.
  4. Concentrate on the grey square area with the arrays of dots. This is the "form." The pinboard shows where components like buttons and text boxes will be installed to make a complete graphic user interface (GUI). The purpose of the grid is to align the components.
  5. Run your program. Click "Debug" from the menu bar. Click "Start" from the drop down menu. Alternatively, you can press F5 on your keyboard.
  6. Enjoy your first Visual Basic program in its simplest form. It is identical to the form in Step 4 except that the dots are gone. What you are looking at is a stand alone program that exists as an ".exe" file having the same name as your project. You can find it under the MyFirstVBProgram folder by default.
  7. Understand the difference between the two distinct environments of the IDE, the Design Environment and the Debug Environment. You saw the Design Environment in Step 4 of this tutorial. That was the environment where you could design a GUI on the form using your mouse. The Debug Environment takes over during the compilation interval in Step 5. That is where you can insert break points in your source code so that you test the correctness of the program.
Read more: How to Run a Visual Basic Program on a PC ' eHow.com http://www.ehow.com/how_2072757_run-visual-basic-program-pc.html#ixzz17b5EMirN
Dec 09, 2010 | Computers & Internet
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kdfwe42655 Sony Picture on approx 45 seconds;
http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=19 <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem with opening templates in Word 2007
I think you need a service pack with some old libraries supported.. This is quite common when upgrading to higher levels of VB.. eg 3 to 5 or 6 etc. If you have the un-compiled code, it can be fixed.. Or load an early version of VB will also fix it. If you have the code, send it to me. Let me know how it goes.. Rgds,
May 12, 2008 | Microsoft Office Professional 2007 Full...
Help me
this the code for your problem. by the way this for vb6.0
Sub CountCharacters(Text As String)
Dim iVowel As Integer
Dim iCons As Integer
Dim iNum As Integer
Dim iSpace As Integer
Dim iOther As Integer
Dim cnt As Integer
Dim sChar As String
For cnt = 1 To Len(Text)
sChar = LCase(Mid(Text, cnt, 1))
Select Case sChar
Case "a", "e", "i", "o", "u" ' And sometimes "y"?
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
' Includes the first case, but VB matches the first case and stops
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
Case " ", vbTab, vbLf
' Space characters
' Not including vbCr as this will likely be dealing with Windows text
' and I only want to match one character for a newline
iSpace = iSpace + 1
Case Else
If sChar <> vbCr Then iOther = iOther + 1
End Select
Next cnt
Debug.Print "Text: " & Text
Debug.Print "Vowels: " & CStr(iVowel)
Debug.Print "Consonants: " & CStr(iCons)
Debug.Print "Numbers: " & CStr(iNum)
Debug.Print "Space characters: " & CStr(iSpace)
Debug.Print "Other: " & CStr(iOther)
End Sub
Feb 21, 2008 | Computers & Internet
Hpqthb08.exe and HPQDocViewer.exe error messages
Make your system virus and spy ware free. Then unistall all the softwware you needed from HP CD or Web site. Hope this will solve your problem.
Feb 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
