Question about Nikon Speedlight SB-800 TTL Flash
Sb800 misfire after several shots.... when i press the test button a couple of times there's a 2-3 out of ten misfires. I wonder if its on the flash bulb itselt or the circuit board? do you have any idea how to correct this problem. I also tried to reset the flash but it didnt help..... hope you could share some ideas. thanks a lot..
Had that problem for a very long time myself too.
Posted on Apr 04, 2008
2001 buick century P0304 step on gas engine light starts flashing
P0304 is engine misfire #4 cylinder Several things can cause a misfire #1 electrical which you have covered #2 Mechanical Test engine compression is should be around 150 cranking and 120 running . internal valve train components can cause bad compression and the valves then self. #3 fuel injector can be the cause suggest swapping with a know good cylinder and see if misfire follows injector.
Aug 19, 2014 | 2001 Buick Century
My quantum flash is misfiring...fire a few shots, then misfire again.
I can repair it for you or try this first.
Turn power on with no camera connection.
Does it fire by itself?
PC Sync on camera, does flash fires by itself?
Dec 14, 2012 | Quantum Qflash® 5d TTL Flash
Test revealed cylinder 5 is missing on my 98 expedition
You have a bad COP Ignition Coil or several
They only misfire whenever they feel like it
If you had professional software --you could road test in
Mode #06 & look at cylinder misfire counts
You need to buy a couple of coils & try in cylinder #5,
front one drivers side
If that isn't the correct one or you have several,walk the
other new coil to get to the bad ones
Disregard any other stray codes until the coil issues are
solved
If it stays on your have Class B misfire
If it flashes you have a Class A misfire that could
damage the exhaust converter
Dec 03, 2012 | Cars & Trucks
2000 Celica GT engine misfires periodically
Hello, it could be an injector problem, try replacing the #2 injector/.
Jul 17, 2017 | 2000 Toyota Celica
Yamaha diversion 600 runs fine then starts misfiring if u leave u leave it a while it runs fine again
Hi, John and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Fuel filter clogged.
14. Old or contaminated fuel.
15. Fuel tank vent system plugged or carb vent line closed off.
16. Gas cap diaphragm valve faulty.
17. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
18. Carburetor controls misadjusted.
19. Incorrect valve timing.
20. Valve springs floating, weak, or broken.
21. Damaged intake or exhaust valve.
22. Incompatible performance parts.
23. The control module may be in "LIMP" mode.
24. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
91 XJ600S misfire at idle on 2 cylinders
https://yamahaclub.com/forums/topic/20607-98-fzs-600-misfire
Yamaha XJ600S 1992 Service Manual
OEM parts for Yamaha
Yamaha Diversion XJ600N Owner Manual
Aug 01, 2012 | 1999 Yamaha XJ 600 Diversion S-N
Nikon D3 and SB800 flash problem
The Sb800 and the Sb900 is compatible . Can you tell me more of what the problem is .
There is no frim ware for the flash . The NIKON SB 900 FLASH SHOE IS THICKER AND MAKES BETTER CONTACT . THE NIKON SB800 SHOE IS LOOSER AND NEEDS TO BE ADJUSTED
Nov 23, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon sb800 speedlight
The trigger circuit and flash tube needs to be replaced . If you want me to repair this contact .
Berrie Smith Camera Repair
bbmw@bellsouth.net
770-312-0719
Mar 27, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
236 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
